12v USB Hub - $29.99 :-)
  • 12v USB Hub - $29.99 :-)
    Tigerdirect has the Ultra ULT33056 7 port USB Hub for $29.98 and it takes 12v DC in (yes, 12v, not 5v). With Goggle checkout you can even get $5 off, if you add a filler item for $1.
    USB Hub on Tigerdirect
    would be good for someone who bought it to check if the 5V out on the usb ports are stabilised, as this probably wasn't designed for fluctuating voltage.
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
      Can almost garuntee it requires regulated 12v. Try to hook that up to car power and watch it go boom.
      RevFE
      My Shop
        Input: DV 12V 2A
        99% sure as well it doesnt have voltage regulation. not much different then a 5v setup in that case to be honest..
          Yeah, I guess you guys are right, I just got a little excited seeing a 12v one at a good price. I did order one, so we'll see if I fry it or not.
            either way, its still a good deal in my opinion.
            You get a massive 7 usb port and all u have to do is connect it to ur psu's 12V and you're good to go.
              i agree with punky - or you can get MP3CAR's Power Controller Card which costs $25 bucks for use with your monitor and use your existing USB hub.
              CTS 05, Mobile Information Center...
              Atom - 1.8ghz
              2GB Ram
              32GB SSD
              8" TouchScreen
              5.6" Screen (overhead) w/reverse capability
              Finished Project
              Car Hacking
              WorkBlog
              Video
                Quick method for regulating 12+ to 12v steady. There's a voltage drop off of around 1v or so. Using a 7505 or 7509, you can get regulated 5v or 9v too respectively.
                Note: Less then 1 amp load. You cannot get regulated 3amps by just using 3 7512s or the like, so don't try.
                2007 Toyota Tundra Double Cab SR5
                >"Say what you mean and mean what you say"<
                  If you want unregulated 12-24v in, you could buy our p5usb. (currently 50$ with rebate)
                  If you want to use the above product on a budget, you could solder into the 12v rail coming of the atx power supply to use the above hub.
                    could i conect this on the outpout of my power suply wich goes to my xenarc screen?
                    if i can, i need to conect it to the positif and do another ground?
                    or can and juste conect it to the two wires of the screen?
                    Carputer to sell : http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2684
                      which device are you referring to specifically when you say "this"? Which power supply are you using?
                        TigerDirect is garbage. I tried to buy a $280 camcorder from them 2 weeks ago and they wanted me to fax them identification.....WTF? I asked why and he said, "We require it for all orders above $500." Okay.......math fail. I canceled that and another $250 order I was going to make, they're braindead.
                        Ampie Case
                        256 MB DDR2 PC5400
                        Xenarc 700TSV - VGA Monitor
                        Intel D945GCLF Motherboard
                        M2-ATX-HV
                        2005 Honda Civic
                          soorry i am talking about tigerdirect usb hub
                            i have not had any problems with tiger direct, and have gotten all sorts of stuff from them, granted though, there is a outlet store near me, so i just go there, so i can't speak to much on the online side of things.
                            next project? subaru brz
                            carpc undecided
                              How can each of the 7 ports be guaranteed 500ma with only a 2A power supply?
                              My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
