hard drive vs vibrations
  • hard drive vs vibrations
    http://www.carsound.com/cgi-bin/ubbcgi/ultimatebb.cgi?ubb=get_topic;f=1;t=020854
    what do you think???
    asus p5a-b, amd k6II-350, audigy, asus dvd-rom, 192MB, 20GB, noritake LCD...
    I do not think the vibrations will do a thing.... In my experience the orientation of the drive does not matter.
    I have read that some people are concerned about the EM field the speaker magnets have could be an issue.
    There is my 2 cents
    TruckinMP3
    Read the FAQ!
      all depends where the sub is. I'd say you'd be fine. A harddrive can take a a big time beating and still keep on working. If you are really worried get a laptop drive.. but jus tmount it vertically and you should be ok.
      '98 Explorer Sport
      80% done
        the sub is a kicker L715 in a 4.5 cube ported enclosure tuned to 25hz... fed by a JBL P600.1...
          case is already all built with hd mounted vertically...
            It really all comes down to the tollerances of the hd and just exactly the sub is putting out. The threshold for vibration (sinewave) damage is only about .5g while operational, where as they can usually take 50+g operational shocks (2ms).
            -Nick
            _____________________________
            www.mp3vw.com
              Oreintation of the drive does not matter nearly as much as some claim.... over 3 years in service and the drive I am using makes a small whine at startup in cold temps.... that is it. Denver roads are rough.
              TruckinMP3
              Read the FAQ!
