New Build Won't Boot
  • New Build Won't Boot
    I just put together my first build, and it won't boot!
    I'm running a Intel D945GCLF2D, M2-ATX, 2GB RAM, Intel 80GB SSD in a Morex 5677 case.
    When supplied power, the light on the MoBo comes on. When turned on, the CPU fan kicks on, power is supplied to the USB ports and that is it. The case fans don't kick in, no detectable image is being supplied to the monitor, etc...
    Any idea on where I should start looking?
    Memory. Either it's dead or probably it's not compatible with your MB?
    Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
    Skin: MetroSex on the Beach preview
    07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
      Yup, I goofed! My MoBo only takes 667/533 and I have a 800 in it. Thanks, I would have taken weeks to discover that.
        Glad you figured it out! Good luck!
          Well I replaced the memory with an acceptable replacement (DDR2 667MHz 2GB), and there is no change. Still dead. My only idea of a possible issue is my power source while on my work bench. Is 12V 1.2A enough to power such a setup?
            Absolutely not. 12V * 1.2A is 14.4 watts. The mobo/proccessor eat 12 on their own. 5 watts per stick of ram plus an ssd and you're probably getting close to 40-50 watts.
            My Nearly Complete Car:
            http://www.mp3car.com/vbulletin/show...ed-car-pc.html
            Micro Control Center... Control Your Car Across the Internet
            http://www.mp3car.com/fusion-brain/1...-internet.html
            Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
            http://paulfurtado.com/
              Thanks. I'll have to go find a power supply that puts out more amps...
                Exactly. Try this:
                http://www.mp3car.com/vbulletin/faq-...workbench.html
                  Yeah that's definitely the best way to go about it. I would have sent you that link, but it was late last night and I figured some answer would at least get you on some track.
                    So I finally got some free time and I am still in the same situation. I was given a RV/Marine deep-cycle battery, so that is my current bench power supply now.
                    I'm still having issues with booting, when supplied power, the light on the MoBo comes on. When turned on, the CPU fan kicks on, power is supplied to the USB ports and that is it. The case fans don't kick in, no detectable image is being supplied to the monitor, etc...
                    On my M2-ATX I'm using mode 0 for testing. J8 and J9 are both connected.
                    I'm not sure where to go now... Any suggestions?
                    Edit: Stupid question, but do I need the P4 cable from my PSU to my MoBo for my CPU to run? Intel D945GCLF2D MoBo and M2-ATX PSU.
                      that was just what i was going to recommend--- you will need the P4 cable--otherwise, the processor won't start up...
                      next project? subaru brz
                      carpc undecided
                        Thanks, I just ordered one.
                        Now I have to figure out how to power my monitor w/o an inverter! I was using the P4 to output power to the monitor and bought the quick release power cable kit from this site in order to do just that.
                          just so we are both on the same page, you mean the 4 pin connector that has 2 grounds and a 12 and 5 volt lead instead of 2 grounds and 2 12 volt leads?
                          usually, the rectangular 4 pin connector with both 12 & 5 volt power is refered to as a 4 pin molex connector, and the square 4 pin processor power connector is refered to as a p4, or processor power connector--just so your aware of it later on in case you need some help trouble shooting it any more
                          for your lack of power connectors, maybe something like this could help?: http://www.microbarn.com/details.aspx?rid=100071
                          carpc undecided
