audio interface question
  • audio interface question
    ok im wondering a cheap way to get the audio from my sound card amplified onto my speakers. My current alpine cd player has no aux input and I am not looking to add a large 4 channel amp...maybe a cheap one? Do they make certain fm modulators for this or somthing? Just wondering if anyone out there had a good solution to share =) Thanks!
    forgot to mention i already have a monster 400 wat sub amp hooked up, so any other larger 4channel amp would be a) too expensive for me and b) take too much power (i would need a capacitor or somthing).
      Originally posted by evank:
      <STRONG>forgot to mention i already have a monster 400 wat sub amp hooked up, so any other larger 4channel amp would be a) too expensive for me and b) take too much power (i would need a capacitor or somthing).</STRONG>
      your expense reason is fair enough.... but the take too much power I dont think so. Most power amps are very much overrated..... if you have a good car battery and healthy alternator you should have no problems.... capacitor's are a bit of a joke/band-aid solution in most systems.
      Project - GAME OVER :(
        your right, it would probabally be okay. assuming i had the money to pay for a 4 channel amp heh. i was looking for a different solution...
          Sorry, I really don't see any other solutions. I have an amp running my highs and mids now that I have gotten rid of my subs and sub amp and I am going to have to plug the computer into the aux in of the amp. That is until I get a new head unit. I haven't l;ooked around much, but I am hoping that the cheapest head unit that has aux in shouldn't be TOO expensive.
            http://www.funmp3players.com/store/p...MP3%20Hardware
            i found exactly what i was looking for, short wave fm modulator! it was hard but i found it heh.
              <STRONG>http://www.funmp3players.com/store/p...MP3%20Hardware
              i found exactly what i was looking for, short wave fm modulator! it was hard but i found it heh.</STRONG>
              best of luck, you might want to search the BB before you part with your dollars, since
              I know a few members have had some bad experences with certain FM modulators. No FM modulator is ever gonna sound as good as a direct connection anyway......
                I highly recommend against going with an FM modulator. I'm using an FM modulator very much like the one you linked to and it's garbage. I have to crank the computer volume all the way up just to be able to hear it, then there's alot of hiss and a bit of distortion... all around not a good solution. I've had some success playing with different sound cards (old sound cards with built-in amplifiers seem to be best such as the old SB 16 ISA cards), but overall it's not worht the headache. If you plan on buying this, you WILL need ot buy a power filter as well, especially if you are powering your PC using an inverter. Even though I grounded the modulator, inverter and PC to the same ground point, hooking the antenna into the modulator seemed to introduce a ground differential as well, so I also had to add a ground loop isolator.
                Take a look at the Aiawa deck at crutchfield. It's only $119 and has an aux-in. This is only $80 more than what you're going to spend on the modulator, and not even that much more when you factor in the $$ on the power filter and ground loop isolator, not to mention the amount of time you'll spend trying different sound cards, etc to get decent sound out of the modulator.
                IT'S NOT WORTH IT!!
                Mike.
                  The aiwa only has mini aux inputs
                  I was hoping for some rca's. I guess I'll keep looking, so far I haven't seen anything for under $250. Let me know if you know of anything cheaper. Thanks
                    does your alpine head unit have changer controls? If so, is it AI net? If yes you can buy an $80 inline adapter that will allow you to bring in a rca input and will display as AUX on the display.
                    1999 voyager pontoon boat
                    (soon to be computerized)
                      sweet, is that specifically for the alpine units, or are there adapters for most of the major manufacturers? thanks!
                        If you are looking for good car audio equipment and not to expensive look at www.sounddomain.com and www.soundcity.com. I have not bought anything from soundcity but have from sounddomain and I really like them. I got my head unit for around half the retail price. I am having the same problem that you are having also. I just bought a new head unit not more than a year ago.
                          You dont' need the $80 adapter unless you are using a CD Changer, too... Without the Changer, there is a $15 adapter (KCA-121B) that will only work if you have the audio mute function available on your head unit. Check out this post for more info:
                          http://www.mp3car.com/vbulletin/show...&threadid=8784
                          - Aaron
                          '98 Malibu LS
                          MP3 system 80% complete
                          hardware:
                          *Alpine CDA-7832 w/ AiNET aux adapter
                          *Tyan Tomcat i810ef / Celeron 566 / 128MB
                          *WD 6.4GB
                          *Seiko L2014 LCD
                          *Numeric Keypad
                          *Jeff's ATX Shutdown Controller
                          software:
                          *WinME w/ 98Lite install
                          *WinAMP
                          *Lorty's Plugin (registered)
                            this is what you need to add your carputer to your system when you don't have an aux input on your head unit
                            http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-806
                            99.9% complete.
                            http://www.cardomain.com/ride/212327
                              Yeah, the line-level switch is a good cheap solution... The only drawback is that now you have to control volume for your head unit, and a seperate volume for the mp3s. Getting an input into the head unit is ideal since you can use it to control everything (plus you can use its EQ if available, etc...). Plus, some people don't have amps in the car and are just using the HU's power to drive the speakers...
                              - Aaron
                              '98 Malibu LS
                              hardware:
                              *WD 6.4GB
                              *Seiko L2014 LCD
                              *Numeric Keypad
                              software:
                              *WinAMP
