Shuttle FV24 Video out problem
  • Shuttle FV24 Video out problem
    Everything is fine from the VGA port but SVHS is outputting nothing...
    Have I blown the chrontel chip?
    I know everything before the screen is fine...
    ive checked all bios settings, not there
    is this a common problem?
    If so is there a fix other than sending the mobo back to manufacturers, maybe a bios flash or so?
    My processor cooked in the machine a week or so back could it be related?
    Jose
    John McLear - [email protected]
    http://www.205oc.co.uk
    UK Mp3car slapnut
    #mp3car - Efnet
    Carplayer and Mediaengine *****
    spank gemma.co.uk for holding my motherboard for so long. still no board, wood work nearly done :|
    [-----------(90%)----] Completed :)
    pics at: http://www.zcentric.com/~mitcht/gall...me=Convertable
    some tv chips will not let you use VGA output and VIDEO output at the same time, so if you have them both hooked up at the same time i would try using only the video out port and see what u get--good luck
    DigitalDub
    1200 mhz duron/ 384m pc133/ 6.4 gig for OS / 75 gig storage/ 32 meg Nvidia Geforce2 wit TV out / onboard sound / GPRS / 7" digitallww flip out / X10 Mouseremote / 255w inverter (temp)
    Audio
    Nakamichi CD-45Z HU / Monsoon amp and 8 speakers
      nop that aint the case
      UK Mp3car slapnut
      #mp3car - Efnet
        is there dif types of svhs signals,, pal/ntsc style? I assumed it was a worldwide standard?
        UK Mp3car slapnut
        #mp3car - Efnet
          Im pretty sure that svideo is svideo. Im not familiar with the fv25, but there's not a jumper or dip switch to pick the svideo or the composite video is there? also, I know on my epia m, the svideo was the default choice for tv out, it might be the opposite for this.
          -Nick
          _____________________________
          www.mp3vw.com
            Some things to check
            Open up your bios and on the main screen (where you set up drives) there will be a setting for the display type. Set it to tv or tv + crt. If that option is not there, you need to update your system bios. There was a nice chart on the shuttle site that they called an fv24 faq, but they seem to have changed everything around and i cant find it. This was the next best thing i could find
            RL=http://www.shuttle.com/new/support/download/dwn.asp]http://www.shuttle.com/new/support/download/dwn.asp[/URL]
            This should atleast allow you to see the post screens. If you see post but video goes away when windows starts, you have a driver/setting problem.
            Check to see that the display you are using has around 75 ohms on the video input. If the video input has a very high impedence, the mainboard will not be able to detect its presence and will not enable the video out. A quick test would be to connect the fv24 to a regular tv which will have the correct input impedence. You can search the board for fixes if this is your problem.
            check to make sure your wires are good, correct input selected on your display, etc.
            If youve checked these things and still can see the post screen, you have a bad board.
            mike
            91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
              yeah I looked at chronotel chip has a slight brown marking on it, gone back to Mft
              UK Mp3car slapnut
              #mp3car - Efnet
