Check out the Next Gen VIA C3 Motherboard. (SMALL!)
  • Check out the Next Gen VIA C3 Motherboard. (SMALL!)
    Check out the size of this thing perfect carputer material.
    Damn thats small! I want one. Should make those DIN sized installations even more common.
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
      If that widest (the connector plane) side fits inside the width of a Din enclosure, you could easily squeeze that and a Laptop HDD, and slot DVD, + a decent naked PSU inside a single din box, and maybe even fit the screen for a din and a half/ 2 din..
      4x4 in a turbo stylee.
        This sound like a familiar 3.5" inch factor mothervoard...
        This is quite common on industrial motherboard...
        3.5" FDD SubCompact Form Factor
        Onboard Mobile Intel® Celeron® ULP or Mobile Intel® Pentium® III LP processor
        SMI Lynx3DM+ SM 722G4 LCD controller with built-in 4MB SGRAM supports 24-bit TTL/LVDS TFT Panels
        Supports NTSC/PAL TV output
        Integrated SoundBlaster-compatible PCI audio
        Supports Type II CompactFlash Memory
        10/100Base-T Fast Ethernet
        Optional Gigabit Ethernet
        2 COMs / 1 Parallel / 2 USBs / 1 IrDA
        5V only operation
        Cool...but not the price as all the industrial compact board market...
        VIA Eden is the only affordable "compact" 17x17 board for the public market...
        Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
          very, very, very nice...
          I they did a version with more ethernet, possibly a PCMCIA connector too, but without having to stack another board on top of it.
          How many of these can you fit in 1U with drives
            The best thing is this core running full speed only requires a mere 11 watts.
