e46, Rear-View, Relay... suggestions to relay...
  • e46, Rear-View, Relay... suggestions to relay...
    So I've had this rear-view mounted in my keyhole for over a year now. I hooked it up to my reverse lights to get power, thinking that would do the trick.
    Well it sorta did -- though from what I recall, the power to the backup lights are intermittent, and not a solid source of power... which works to some degree, but the picture is almost fuzzy at best...
    Again from what I recall I need to have a power relay switch that will let me have a power supply of clean power, but get triggered from something like the reverse lights going on.
    Any suggestions or threads that you're aware of that I couldn't find that may help me out?
    Thanks everyone!
    Ok, so I stumbled upon a page that gives a huge walkthrough (overkill for what I'm wanting) of integrating tv/rear-view into a 7 series... but the takeaway here for me is the mention of the relay switch
    (if interested http://www.bimmerboard.com/forums/posts/140540/ )
    They mention a 'Standard Automotive Relay" ... with a picture!
    Any recommendations for a particular relay such as this?
      Intermittent power to backup light!?? Are you sure? If so, a relay will not help you.
      Have you connected to the right wire?
      One thing that might cause a problem is the "lamp fault detection". In that case the relay might help. I am sure any car relay on the nearest gas station will do.
      Hope it helped-
      My car installation mp3car thread "showing off project"
        Yes actually. Matter of fact, I think i've found the identical one listed that the guy used (based on just the picture) : The Pilot PL-RY1 for $7.99
        I don't mean intermittent... again from memory, but the way it was explained to me was that the reverse lights do not get a steady source of power.. but a variable -- very fast, but variable... such that it wont sustain solid power to power the cam... but enough to trip a relay.
        ... then again I could have gotten some crappy data too . I know the cam works, hooked it up in the house just fine.
        -- Matt
          Do you have LED taillights or standard incandescent bulbs? If it's LED then my guess is they are powered with a PWM signal to control brightness, which would match with what you are describing.
          98' Honda CR-V
          http://www.superbluecrv.com
          *OBDMPG, the RR OBD Plugin*
            Nope. They're not LED lights...
            I'm going to go test this again, using a straight-wired 12v power just to see..
              whelp... I feel like a real big dumb-dumb ...
              I have no idea what happened from last time to this time... but it works perfectly. go figure...
              Thanks for the input anyway guys
