m2-atx quick LED flash ?
  • m2-atx quick LED flash ?
    Hi there
    Got a m2-atx power supply , connected it up off of the 12v rail on my PC power supply.. basically as soon as i turn on the Power supplys main pc power the LED just flashes and goes off.
    I havnt got nothing connected to it ... Just the m2-atx .. to the mainboard and the p4 connector .. No switch wire connected.. I assume the LED is ment to stay lit ?
    When i use a normal PC power suppy on it , its fine
    any help will be apreciated
    thanks
    Luke
    try adding the power switch lead to your setup, if this does not work try pluging in a 3.5 inch hard drive, it sounds like their isnt enough load on the 12v line for the power suppy to boot.
      thats what i also assumed ( power to low)
      ill try adding everything again .
      thanks for the responce.
