New Mini ITX Motherboard from Intel D510MO/Mount Olive
  • New Mini ITX Motherboard from Intel D510MO/Mount Olive
    Intel's newest Mini board the D510M or Mount Olive is set to be launched in the beginning of January. We have had the privilege of testing this board for the last 2 months and have been quite impressed with it.
    The Mount Olive is Intel's followup board the the D945GCLF2 and has some nice features that the LF2 was missing.
    Here is a quick run down on the specs, features, and highlights:
    Estimated price $95
    Dual Core 1.66GHz Pineview CPU Embedded
    Support for 4GB of RAM
    Totally fanless
    Draws 50% less power than the LF2
    Has a Mini PCIe slot
    Faster FSB 667Mhz
    It will come in 3 flavors
    Standard- no com or lpt ports on the I/O shield headers for them only
    Legacy- will have COM and LPT ports on the I/O shield
    LVDS- no COM or LPT ports on the I/o but it will have support for LVDS
    Runs Windows 7 like a champ
    We did find a few draw backs as well:
    With the exception of the LVDS option the only choice for video output is VGS
    There is no IDE or EIDE bus at all, just 2 SATA II connectors.
    Has a tall heat sink (we already have a shorter one being made so it will fit more cases)
    I will post more detailed specs on the board and our test results when I have more time. If any one has any specific questions about this board post them here and I will do my best to answer them.
    how is the bios? is it faster than the LF2? more flexible?
      i don't understand if svideo connection is mantained
      may i have more info about?
      Huawei Mediapad 7" (1280x800 IPS) | Carnetix P2140
      My last update http://www.mp3car.com/show-off-your-...t-version.html
        Punky,
        I will post the bios post times shortly. What do you mean by more flexible?
        Aziodale,
        No there will be no more S-video
          what chipset? I hope not GMA500.
          Former author of LinuxICE, nghost, nobdy.
          Current author of Automotive Message Broker (AMB).
          Works on Tizen IVI. Does not represent anyone or anything but himself.
            Here's some more info and pictures.
            The spec looks promising, but the design is poor, especially for small, in-car usage:
            -too few USB connectors
            -no optical/coax audio connector
            -the ram slots are too close to each other, and to the heatsink
            -the power connector is in the center of the board
            -audio connectors are too close to the PCI slot (could be a problem)
            We should wait for the Zotac or ASUS version of it...
            The basic idea was good, skipping legacy connectors and controllers is a good thing.
            Maybe they should make a board without onboard audio, instead of using a crappy one
            The best would be an ultralight version without audio, ps/2, onboard lan, but with 10-16 USB connectors
            Check my worklog:
            Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
            Lord of the boards: DFI CP100-NRM
            "Or you can try Ubuntu, but than don't tell everyone you are using linux,
            because it's just a secret unreleased prebeta of Windows 3829" :P
              Why get rid of all the legacy connections like com, lpt, IDE/PATA...yet keep the same old ancient PCI slot.
                Hey hey, no more P4 power connector either.
                Nay, a brand new chipset, the NM10.
                Tidder
                Try RevFE
                  I was wondering if it had more options than previous LF2 bios, ie quickbook, usb boot, or anything new that wasn't already in the LF2 bios.
                  How would the board work without the P4 connector? especially with PSU with the P4 connector? Or is it as simple as leaving the P4 connector and the psu will be operational as usual?
                  Fanless is really nice!
                    Marketing reasons, an atom with a decent PCIe video card can kill low-end processors
                    on the market. Also, there are still many PCI devices, for example sound cards, servo controllers, etc.
                    (no, you can't just use USB, it's slow)
                    The energy consumption of the board is very low, so it doesn't need a P4 connector.
                    Check my worklog:
                      The graphics is GMA3150 I believe
                      The time to post is identical to the LF2
                        Yes, it is GMA3150, according to mini-box
                        Check my worklog:
                          dam# marketing
                          I'd love a lower power setup that's very capable... but I'm not giving up my PCI-E sound card to do so. They're already making 2 versions of the board... legacy and non... why not throw in the PCI-E on the non-legacy version and leave the legacy with the PCI. Then again...I know the answer to that too unfortunately
                          it's like
                            probably have to postpone the mb buy for some time then
                              I think it's safe to buy Asus AT3N7A-1, we've got about 30 mini-PC's based on it
                              (at my workplace), quite impressive. Ideal for CarPC/HTPC use I think.
                              Check my worklog:
