Would it be bad to have bottom of motherboard pressed up against cardboard?
  • Would it be bad to have bottom of motherboard pressed up against cardboard?
    I am making a minimalistic case for my carpc and I was wondering if this would cause any problems.
    as long as the cardboard isn't conductive you'll be fine. make sure no metal can put a hole in the cardboard.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
      Ok, thanks Paul
        i have used cardboard for short term use, and think it is fine for that, but because cardboard disintegrates after it gets damp, i would not recommend it for car use. some thin lexan/plexiglass(whatever you can get cheaper) would probably do better in a car environment.
        next project? subaru brz
        carpc undecided
          My whole case is cardboard. (See my latest posts in my worklog) I took some EnviroTec resin (meant to be used like polyurethane to give tabletops a glass-like finish) and brushed it onto the cardboard until it soaked through. It dries like a plastic with a glassy finish in two or three days.
          After a 2 year break, I'm back! There are so many new and familiar faces here!
          New vehicle, new ideas!
          Chryssi - The Changeling CarPC Project
            MDF works good too. I have used it for a base for 2 setups and had no issues...
              good ideas. thanks everyone
                Cardboard or anything that can hold moisture is not a good idea, or anything that's semi-conductive of course. High humidity or a rainy day and it could soak up some moisture and have a high resistance between many pins on the board and cause unexpected results. That moisture can also breed mold/mildew which is organic and conductive along with increased risk of rust in the long term on any metal touching it.
