Plug wires into PSU
  • Plug wires into PSU
    I recently bought a homemade touch screen and the power connection is through a wire marked negative and one marked as positive, would this be possible for me to test by plugging it into an old computer power supply somehow?
    Sorry if this is a dumb question, I tried searching but I wasn't exactly sure how to word the problem right.
    yes this is pefectally possible you would need to know if it was 12v or 5v, by looking at the invertors user manuel you should be able to work that out
      What if I was using a dc-dc power supply?
        I think he meant the inverter that is built into the screen to produce the light. Either way, what model is the screen? You can probably find its power requirements in a manual online.
        If it runs on 12 volts which it most likely will, yellow wires on a computer power supply are +12v. The black wire right near it in a hard drive connector would be the negative. For 5 volts, look to the red wire and the black wire right near it.
        My Nearly Complete Car:
        http://www.mp3car.com/vbulletin/show...ed-car-pc.html
        Micro Control Center... Control Your Car Across the Internet
        http://www.mp3car.com/fusion-brain/1...-internet.html
        Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
        http://paulfurtado.com/
          That worked great, thanks
            Awesome, that's what I like to hear.
