Mini-ITX Powerfull motherboard
  • Mini-ITX Powerfull motherboard
    Hi,
    Im looking new motherboard for my system. I have Travla C137 Mini-ITX Case which support Mini-ITX motherboards. But I think I can put Micro ATX motherboard into it too...
    So my requirements:
    -Support for QUAD/Extreme Intel CPU socket 755
    -PCI slot(PCI slot that does NOT internally share resources) - VERY IMPORTANT because I will have Sound card in this slot
    -Have VGA and HDMI output
    -Min. 4 Backplate USB
    -S3 Sleep Support - VERY IMPORTANT (I will run Hibryd sleep)
    -Windows 7 Support - VERY IMPORTANT
    -SATAII (I will run SSD)
    -Fast BIOS POST
    Reccomended:
    -WIFI onboard
    I DON'T need floppy, IDE, IEEE1394
    Is there any Mini-ITX board which meet my requirements?
    If I will buy Micro ATX then looks Zotac GF9300-A-E right choise but must ask manufacturer about PCI slot's...
    Curently use Jetway NF93-LF and intel P8400 CPU but motherboard give me a lot of headache because share PCI slot resources with:
    -Integrated graphiic card
    -Mini PCI Express slot
    -USB devices
    -SATA controller
    And have big problems with crackling sound. Also CPU is not powerfull enought to run all things I need...
    Thanks for any help...
    Zotac GF9300-I-E or GF9300-G-E board is mini-itx and is just what you need. Not sure about the PCI slot, but should work well with your sound card because zotac is a pretty reputable company.
      Both are not option for my system because do not have PCI slot. They have only PCI Express slot...
        I see... well good luck with finding a mini-itx board with a PCI slot
          What about Micro ATX motherboard? I will modify case if will not fit
            Any of these (they all have PCI slot[s] and SATA)
            Brian
            2008 Grand Prix GXP
            [=====-------] 50% - Main Hardware Complete
              Dg45fc.. I love this mobo so much i'm buying a second one to make a htpc. Its compatible with core 2 duo/ quad core CPUS. All the power in the world. It runs CF3 high graphics profile with visualizations running at 3-6% cpu with an e8400 processor. HD video and HD audio ready from the box. 10 USB ports.
              Live mp3Car Facebook Chat
                I would have to vote for the Zotac 9300 strictly for the onboard geforce graphics card.
                  Save your pennies for Zotac's newest ITX.
                  clarkdaleready-miniitx-motherboard
                  Mal
                  Vehicle: [100%] 1995 C 1500 ECLB
                  Gear: [90%]
                  Build: [80%] PC & Chassis, Worklog
                    why worry about quick post speed if you're using s3 sleep anyway?
                    it'll limit your selection choice quite a bit and it doesn't really change the performance.
                      Mal
                      As Im say is not option. It DO NOT HAVE PCI SLOT.
                      Because I will use hibryd sleep and if PC is more than 2h in S3 PSU cut of power and next time I turn it it make hibernate, this is reason for need quick POST... So when I just go to shop it turn on from S3 when I lave it over night it resume from hibernate...
                        what kind of battery are u using? what psu?
                        because you can leave a car on s3 sleep a lot longer than you might think. Mine is setup for voltage instead of a timer, so if my battery's voltage drop below 12.3V (or whatever i like) the psu will hard shutdown. And I've left my car for 2 - 3 days without hard shutdown happening.
                        I drive my car everyday so it has to stay on s3 at least 12h/day which has never been a problem.
                          What about ASUS AT3N7A-I? Dual-core 1.6Ghz atom, pci slot, 8+2 USB, VGA, HDMI, 7.1 analog/digital,
                          NVIDIA ION GeForce 9300
                          Check my worklog:
                          Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
                          Lord of the boards: DFI CP100-NRM
                          "Or you can try Ubuntu, but than don't tell everyone you are using linux,
                          because it's just a secret unreleased prebeta of Windows 3829" :P
                            I have few 3 battery's in my car. 2x Fiamm FLB400(100Ah 4000A) and 1x another battery with 70Ah 2500A which will be replaced with Fiamm FLB300(75Ah 3000A). But I have little hungry audio system:
                            Audison VRX 2.400(2x250WRMS at 4Ohm and 12.6V)
                            Audison VRX 4.300(4x110WRMS at 4Ohm and 12.6V)
                            Audison VRX 1.500(1x2000WRMS at 1Ohm and 13,8V)
                            All 3 amplifiers are AB class. Reason why I don't want leave it more than 2h in S3 is that I don't want to much empty battery which can effect on my audio system...
                            Atom CPU is not powerfull enought. Currently I have Intel P8400 CPU which is Dual Core 2.4GHz and with very simple audio processing I get 20-40% CPU usage. In mode which I would like use this CPU can handle only two channel when I add aditional two all start crackling and stuttering...
                              I would imagine it isn't powerful enough for him.
                              Although I do question why you say the cpu isn't powerful enough? An 8400 is a pretty good everyday processor, what are you doing on a carpc to use it up?
                              I like the Zotac boards, I've done two builds for people with them and had no problems. Great bang for buck feature wise, and I didn't have any driver problems. I used the mini-itx 9300 though.
                              A quick power search on newegg reveals nothing, although they don't carry much in the ways of mini-itx. A good 75 results in matx tho. http://www.mini-itx.com/store/?c=49 <- that is a 775 socket mini itx with a pci slot, you will have to read through for the other features... Its an Intel DG41MJ.
