Inverter question in regard to backlights
  • Inverter question in regard to backlights
    Is it posible to fry an inverter if the backlight does not match or was NOT made for the specific inverter?
    I ask because I would like to get another backlight for my setup, but it has been really dificult. I have noticed its easier for me to find an actual screen than find the backlight.
    Plz shed some light on the subject.
    What im curently listening to.
    My complete carpc setup
    Nope, frying the inverter should not be a concern. However, you may find it difficult to physically install a backlight that was not made specifically for your display.
      what kind of screen do you need a back light for?
      we have several in stock,
        I need a backlight for a Sharp LQ10D361. if you got let me know. Although it will be in a couple of weeks, because I just ordered a Sharp LQ10DX01 from Ebay. So if the one off this screen does not work I will definatly order from you.
        M with the info, or post away.
          As long as the replacement backlight it rougly the same size and brightness, you should not have a problem with the inverter.
          I recall having seen CCFL tubes in the Digikey catalog. Maybe they have something suitable for you?
          white bream
          working on a trilogy: CARGO - UNIGO - MERGO
          CARGO = the Car Computer
          Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
          Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
            I tried them and they reffered me to JKL. Still no joy.
              Some people here said they've used the ones from All Electronics
              It's under Lamps>Flourescent
              You can find the appropriate length tube there and it may work - and they're cheap!
              - Jeff
              95 Mustang GT Convertible
              87 Mustang GT Convertible
              My Project | Let's Go Mets! | SCT Tuners
              Project Status [===#===] [Bezel and dash creation]
