psuedo start up controller, help :)
  • psuedo start up controller, help :)
    ok... this may need to be moved to power supplies but we'll see...
    First let me say what hardware I have:
    -Dell Inspiron 8000 Laptop (850Mhz pIII, 256ram, 40g, dvd, sans lcd... picked it up cheap on ebay)
    -7" in dash touch lcd (well, will have as soon as DigitalWW sells em)
    -JVC Kameleon LX-50 head unit (aux input)
    -Power will be supplied by a dell car adaptor unit.... its really just a regulated dc -> dc supply so no biggie here I've got everything powered up and it works fine.
    Ok, here is how I would like the system to work I've got the "basics" covered but need a little help designing the circut... I know it won't be complex but still need a little help
    Basically I want a relay that sits on the remote ("amp") on line from the head unit that when powered turns on the 12v to the DC adaptor for the laptop and somehow activates a momentary switch to turn on the laptop. Then when the car (or head unit) is turned off the relay will disengage and the dc adaptor will turn off.
    ----------- already have this party done -----------
    then when the laptop goes from "DC" to battery power it will auto hibernate after 20 min of battery power.
    I know the relay for the dc adaptor will be easy... I think the only hard part will be getting it to somehow activate a momentary switch or I can hard wire the switch and somehow just have something complete the circut for a minimal amount of time... I don't know really thats why I'm looking for help...
    thanks!
    -- WireSix, Inc. --
    MP3Car Lives Here!
    *bump*
    -- WireSix, Inc. --
    MP3Car Lives Here!
      Give this a try:
      When you apply 12v, the capacitor "acts" like a short, bypassing the resistor and energizing the relay. The C and NO contacts will be on for a time determined by the resistor/capacitor values. When the capacitor is fully charged, the relay will be turned off (even with power applied to it).
      This resistor/capacitor combination will give you approx. 1/2 second. Increase the capacitor value to increase the on time.
      When you remove power, the cap will discharged through the resistor.
      The capacitor should be rated at min. 25 volts.
        Can somebody please repost this circuit? It seems to have disappeared and I need it!
        Originally posted by mp3hombre
        Give this a try:
          bump
          My Carputer! (More Car Pics at the end)
          2 Kicker Comp 10"
          Epia M-9000, 256 MB DDR, 120 Gig HD
          Lilliput 7" VGA Touchscreen
          Check it out?!
            If you want to use something simple and pre-packaged, for ~$40(US) this might be a good solution.
            PTR-7
            It seems to have a lot of flexibility for custom ON/Off, timed, and pulse functions. Option 12 is probably your best bet. (Table in the .pdf file)
            Possible sources:
            One
            Two
            Car PC - If you have to ask why, you'll never understand.
            XAA289.com
              Here's the stupid question, i have a Dell Inspiron too but a 2500... How do you get the laptop to turn on without opening the laptop and pushing the power button? On my bookpc i had a option of resume on AC loss but on the laptop i don't have that function... ANy suggestions?
              Possible sources:
              One
              Two[/QUOTE]
              1997 Mazda 626 ES [Cronos] - 2.5L V6
              http://www.cardomain.com/id/hmany2k
                Anyone have anything on their laptops called wake on ring? I have it on my laptop. It looks at the RI line of the serial port. You provide 12v to it and the computer powers up. Take a look in your bios for it. If you have it let me know and I'll help you figure it all out.
                Tom
                1993 Probe GT
                Rio Car w/20gb
                  Nope can't say i have that either... Any other suggestions =(
                  Tom
                    Here's my $0.02. I've got an old laptop installed in the dash that I semi-permanently have the power button fastened in the down position. This allows it to power up when power is applied to the dc-dc car adapter and power down when the power is cut.
                    Some laptop power supplies will reset if the power button is held down...luckily mine doesn't...otherwise this literally $0.10 idea would not work.
                    I running win98se with the scandisk off and with a couple hundred ungraceful shutdowns it has yet to corrupt.
                      I opened the laptop, soldered some wires to my power button, and mounted the button in the dash.
                      current projects
                        Well, mine is one of those rubber push button contact things... I would rewire it but it's not a typical ATX type power plug... Any suggestions on how to wire it... It's just some wierd Dell Inspiron setup....
