slot load dvd question
  • slot load dvd question
    Hi,
    my question is simple , can i use a slot load dvd in vertical position ?
    yes
    If your opening is upwards however, you'll wear out the eject mechanism faster. I've done it.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
      thanks for your answer!
        The Wii uses a vertical slot load.
        PROGRESS:
        Hardware: 100%
        Software: 99% - Always upgrading and improving.
        Installation: 100%
        WORKLOG:
        2005 F-150
          its more horizontal if u loook @ it the way we are.
          the wii is almost like laying the drive its side. but the ejection mechanism is still pushing out horizontally.
          the OP is probably referring to the disc being ejected UPward.
          trinybwoy
          2006 Mazda6 Carpc
          2008 Acura TSX Nexus 7
            Oh, ok. My mistake.
            PROGRESS:
            Hardware: 100%
            Installation: 100%
            WORKLOG:
            2005 F-150
              What about the drives that do not slot load, the "laptop" style trays that POP then you have to actually pull the tray out... Would that wear out faster too>?
              Carputer Progress
              [||||||||||] 100%
              Finally Installed!!
              Everything is in the car and working.
              I painted the cilpboard mount and it looks good.
              Shutdown/Startup is working excellent!
              View My Progress Here
                They might, it's lightweight mechanics working against gravity. At least with the tray load drives, you could push a paperclip in and manually eject the tray.
                FAQ to the FAQ - Great Starting Point
                My 2006 Honda Accord Carputer - Work In Progress
                My 1997 Chrysler Concorde Carputer - Died
                  Load a disc on one of those as you hit a bump and you're buying a new optical drive because the tray is snapped, making it useless.
                  How about the Wiki?
