MIniITX without Atom CPU?
  • MIniITX without Atom CPU?
    are there any NEW MiniItx motherboards around that do not have built in Atom Cpus with Normal PCI (not express)
    I want something more powerfull..like a normal CPU.. i have a DSATX and i don't care about power much.
    I use Intel DG41MJ
    I think it is the only Mini-ITX board with a 775 Socket and PCI slot
    I works OK
    I have some issues with the usb slots ( seems like it lacks a little bit power ) which I kinda manage to handle with a powered hub
    But other than that it works really well
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
      what CPU r you using..and what power supply?
        E7500 On M4-ATX
          Originally posted by Madboy View Post
          E7500 On M4-ATX
          r u sure it is the only one? unfortunately it has no HDMI and no serial port
            There are two AMD boards that I found right away with your requirement of MiniITX and PCI slot:
            JetWay JNC84-LF
            JetWay JNC81-LF
            "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
              You got a serial port inside ( pinout )
              And why do you need HDMI? you got a DVI on it..
              And yeah I was only talking about Intel CPU's ( Not a fan for AMD - for no reason actually )
                you r probably right..
                are there any cases that support the PCI? or does everyboy use a riser and having the pci card hidden?
                  My Car-PC is under the seat
                  So I actually use a Mini-ITX cube case : CFI-A8989
                  http://www.chyangfun.com/pro04_1_1.asp
                  If you have the room for it , I really recommend it
                    mo-co-so.com has a case with a pci-slot
                    Former author of LinuxICE, nghost, nobdy.
                    Current author of Automotive Message Broker (AMB).
                    Works on Tizen IVI. Does not represent anyone or anything but himself.
                      I just ordered a
                      ZOTAC GF9300-I-E LGA 775 NVIDIA GeForce 9300 HDMI Mini ITX Intel Motherboard
                      from newegg.com. It is supposed to come in Friday. I ordered it because it is one of the newer boards (DEC09) that supports a 755 socket. I had a older core2duo 2.6ghz laying around and some DDR2 ram. It seemed like the best and cheapest option.
                      *********Just reread the post and see that you are looking for reg PCI slot sorry****************
                        you r right!!!!!i like that case!!!!
                        http://www.mo-co-so.com/ProductDetai...Show=TechSpecs
                          i have a similar cube case + a micro ATX board, in the trunk, i was just looking for something smaller..no way i can squeeze this under the seat
                            I wouldn't limit myself with the PCI slot...there are a lot of adapters that you can use if the board has different PCI connections aside from the old 'normal' standard.
                              what do u mean? i haven't found a pci express-pci dapter anywhere..
