AM/FM Analog & HD Radio Antenna @ same time?
  • AM/FM Analog & HD Radio Antenna @ same time?
    I'm looking to see if it's possible to use the OEM AM/FM analog Radio antenna with a HD Radio (Isimple Gateway HD Radio) for both (HD Radio and OEM head unit AM/FM analog radio) with some thing like a "Y" cable. I would rather not have to use two different antennas but from the info I found if I want to add a semi stealth antenna this post helps for options.
    http://www.mp3car.com/vbulletin/gene...l-welcome.html
    I just talked to Gary @ GLG Direct who has been helpful. Also spoke with I Simple and both said try the BAWM200
    http://bicostereo.com/index.php?act=...productId=4475
    What makes this one stand out over others it's the only two amps. A amp for AM and a different one for FM.
