"Generic non-PNP monitor" goes in and out in device manager
  • "Generic non-PNP monitor" goes in and out in device manager
    Hi All,
    Wondering if anyone has run across this before? I have a 7" transflective liliput, just rebuilt OS with Win7 32bit. I am noticing that in device manager, a generic non-PNP monitor will show up, and then disappear and repeat over and over again (along with the USB disconnect / connect sound) fairly intermittently. I see nothing happening on the screen during these times, i.e. no visible symptoms.
    It's powered off of my 360w Opus and plugged into a hub (which has never given me issues before). I'm going to see if plugging direct to mobo makes a difference, but I would think I'd see the 'touchscreen controller' also disappear during these times (and I'm not)?
    Thoughts appreciated.
    Thanks,
    Per
    as long as it is reconnecting, and disconnecting fine, and it sounds like a loose connection in the usb cable somewhere.
    otherwise, if the usb portion of the ts is bad, it could be trying to tell you-- ie: a device that windows recognises will have the usual 'Ba-ding" noise, where a device that is bad, and not recognised will have a "ba-ba" noise...
    next project? subaru brz
    carpc undecided
