Minimum car battery voltage
  • Minimum car battery voltage
    Does anyboby know what is the minimum voltage of a car battery to start running the engine?
    Enjoint life!
    The more important measurement is amperage, and it depends on the engine size. The larger the engine, the more amperage needed.
    KG6OQD
    www.americansandassociation.org
      If you're trying to measure how much battery life is left in your battery by measuring the voltage, you can't reliably.
      The battery voltage will depend on the load placed across it. A battery can measure fine under no load (say +12V) but once you put your 300A starter across it, then you'll see that it's dead.
