Smart Key
  • Smart Key
    Has anyone messed with / hacked into the Mazda smart key system? I would love to integrate some of that into my carputer. I am not sure if Mazda is different to other OEM solutions. I did some google searching and didn't find a darn thing. Here is what I have.
    The best forum start place is here but damned if I could find it. I had spent several weeks on the forum before finding it.
    If your looking for an easy solution your not going to find one....
    openMobile - An open source C# Front End (why choose openMobile?)
    - Always Recruiting Developers -
    Like what you see? Donations are always welcome
      The BMW smartkeys is super nice... With ODB and propper software you can configure the buttons to do pretty much what ever you want to.
      And with some thinkering you could for instance do what bes51659 have done. When he press "unlock" on the key fob. The car unlocks, and start to boot the PC if it's not already running.
        Heck, what about this whole thing is easy. I am just looking to get a start on it and see if anyone else has done anything with it.
          Thanks, that was one of my thoughts. I did come across some BMW forums / threads that had them all hacked up but unfortunately, the system is different than what Mazda uses.
            having your car unlock and turn on the pc would be easy enough..ish...
            just find the wire that pulses and send the 12V to the door locks and with a relay and a diode or 2 you should be able to do it that way.
            only problem would be if you dash out to your car to get something quickly, unlock it, then you have to wait for the pc to start so you can shut it down..
            I have a boot/trunk release button on my remote which ill use to start the computer from, since i dont have a boot
              That's a cool lookin' key. Looks like you could keep it in your wallet.
              Dodge could learn a trick or two from that. My key is irritatingly big.
                Woofnstuff - I have thought about things like that. I am also looking at more features as well, not just the computer start up. Plus, I never use the FOB as it has a prox switch and I just push a button on the door to unlock.
                Here are some of the things done with other Mazda smart keys, same year, just not in my model. Not all of these are specific to Mazda, but I have seen various cars that could....
                Remote start, lock doors at a certain speed, roll up windows and close sunroof on rain detection, unlock all doors with door button, crack windows at certain temps, shut down car after 120 seconds if key is not detected (car jacking)...
                SenatorIvy - the key is just bigger than a CC but I don't keep it in my wallet. It is a cool key as I don't have to pull anything out of my pocket and push anything on it. I just walk up to my door and push a little button on it.
                  imagine how annoying that would be to not only have to go into your pocket but also into your wallet to get your key out
                  Live mp3Car Facebook Chat
                    Well ideally it would work on proximity and have a start button like Nissan's do.
                      That's why you dont take it out
                      Both our Toyotas (well 1 Toyota and 1 Lexus) have smart keys. It is awesome. Just walk up to the car and it unlocks, sit down and press start and it goes. Get out of the car, press the lock button on the door handle and walk away. Easy and awesome.
                      1.9in x 2.9in -- 47mm x 73mm
                        Exactly!! It's a no brainer with the smart key. I just wish I knew how to hack it / play with it.
                          How do this work with leather gloves on?
                          Is the current the smartkey send, strong enough to go through body and a second layer of thick skin (the leather).
                          I live in Norway, and winter times gets freezing cold. Would hate to take my gloves of, just to unlock the car.
                            It doesn't work that way at all....its an RFID tag...just sends a short range radio signal so when you stand next to the car it can detect the key and allow you to unlock the doors
                              The SKS however is induction based on Toyotas. So with the key in detection range, as long as something like your hand is between the handle and car it will unlock.
