YAJWB Yet Another Jeep Wrangler Build
  • YAJWB Yet Another Jeep Wrangler Build
    So I have a Jeep Wrangler Willys addition. Possibly the worst choice for a car PC choice for anyone interested. The main reasons that it stinks is there is very little good points in the car to make it a viable solution.
    The first main problem is the 1.5 DIN radio. This means you simply cannot easily put a touchscreen in the dash without modifying the dash cluster. And trying to find a place for a 7" in the wrangler is a joke. Its pretty much on the dash.. or under it.
    The next issue is the fact the floor is a furnace. So if you thought you were going to install a car computer or laptop on the floor of the Jeep Wrangler without a heat shield, think again. While there is plenty of places to route wires or connect power, there is limited space.
    So, here I am... I decided on the Lilliput 629GL. And I am running a laptop because of ease of access. Still dont know exactly how I am going to go about this but figured I would start by publically announcing my intentions. By the way... Because it is a Jeep Willys, I dont want to screw up anything stock. I want to use my stock Head Unit and speakers. Its a soft top so I dont care about sound quality and it must be secure and hidden so it doesn't dissapear. While I live in a fairly obscure part of the world, the NY in me says.. make it hard to take. So that is what I will do hopefully. Stock everything. What think?
    Centrafuse 3.1
    Garmin Mobile PC
    GPS, OBDII, Lilliput 629GL, Nightvision integrated video,
    Other fun stuff in works.
    Having increasing trouble trying to find a mounting place for the LCD screen. Location A might be good but would mean that I would either have to hide it by making it move or hide it with servos somehow (Alot of work) or location B might be okay too if there were enough space. the Jeep really stinks for available space. Especially when you dont want to destroy OEM dash. Any other ideas?
    Centrafuse 3.1
    Garmin Mobile PC
      my vote goes to location A-- this will be the easiest, for both the install, and to remove, and hide when needed.
      next project? subaru brz
      carpc undecided
        Aww I thought this was a real willys, not a Crysler jeep
        I agree place A would work the best. Though I would just rip out the radio and use a pop out ^^
        Mage
        =Cars=-
        2001 Kia Optima, V6 4matic fully loaded SE W00t! soon to have a Car pc.
          Mage
          Heh.. Yeah I know I know.. its an X series Wrangler with a bunch of stickers on it.. but... it is the willys edition so :P
          I have thought about this for a long while and dont want to use location A because of visibility issues as well as having to remove it all of the time to avoid possible theft. Plus, in Location B I can secure it in a way that doesn't compromise the OEM looks. Will know more soon
          Thanks for input...
          Centrafuse 3.1
          Garmin Mobile PC
            I beg to differ, I think these cars would be easy to put in a screen.. Of course, anyone on this forum considering doing a carpc realizes it requires some hacking.. If that wasn't the case, we'd all have alpine/pioneer units.. Right?
            These cars are very easy to work on because they don't have much going on (like jap/german cars). All the panels just pop out, and the carpets come out easily to hide wires. I'm telling you i've worked on many cars and chrysler's are VERY easy compared to the rest.
            My recommendation would be to remove the vents, and use that space along with the stock HU space to put in a 7" touch screen..
              This would have been my favorite option as well. However, as said in first post, I have to try and keep this as stock as possible as it will be worth more money in the future because of it.
              The whole 1.5 DIN thing is the killer. If the only thing in the way was the bezel, I would just get another from the junkyard or whatever. But even if... I would still have to hack apart the whole dash structure to make it work.
              One option not yet mentioned would be to float it above the rear-view but... I am not really a fan of the placement.
              Thanks for the response though!
              Centrafuse 3.1
              Garmin Mobile PC
                Hey, i'm sure you did, but did you pop off the bezel and see whats going on back there?
                I've noticed that in chrysler's (maybe not in your's) that the ducts going upto the the vents sit pretty far back, meaning that you'd have enough space to sit your screen without cutting the ducts.
                Though, the structure itself, the frame I guess you can call it behind the bezel will not be wide enough, so you would have to cut into it in certain spots giving you enough access to sit your screen in.
                This could very possibly be done in a way that you could revert to stock without a problem.
                If that doesn't work, why not try use a flip out as mentioned?
                  Flip outs block the vents :S Its too hot down here. like 96 degrees today. And top doesn't come down often because of the baby. Lots of contributing factors and no minivan to put everything in yet... hehehe Oh! Also, in order to replace the head unit (which sounds good in theory) there is alot of extra space on the sides to fill, then there is the ripping apart the wiring and finding a place to mount amps to replace the one in the HU, then there is the radio need for the wifey who may not be able to figure it all out. As said, lost of contributing factors but I think I have a solution with location B. If I cut the bottom of a replacement bezel off, I could mount the screen in the dash at base of the shifter. It is accessible and if hand is resting on shifter, you cna reach out a finger and work controls really easy.
                  Centrafuse 3.1
                  Garmin Mobile PC
                    i'd go with location B too. If you keep your stock HU, how are you going to play the songs off your computer? does the HU have an AUX in?
                      It does not. For now, I will use an FM radio dongle... it works pretty good. Since I am in a soft top, I cant really tell the difference in quality anyhow. But later I would either do the PIX method.. that one that uses the CD changer harness. Its like 80 bucks or something and really unneeded for me right now but the option is there.
                      Centrafuse 3.1
                      Garmin Mobile PC
                        Personally I vote A. I had my lcd half way in between [where your radio is] and i HATED looking "down" at it, so i would imagine looking even farther down would be even worse. my thought is to keep it as high as I can and keep my eyes on the road, so I'm moving mine up as soon as possible
                        MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
                        --worklog--
                          If you did location A, make it look like some sort of glove box to deter theives
                            Well, I got my 629 last night. And as you can see, Location B seems to work for me as of right now. I agree that having to glance that far down can be dangerous and annoying. However, Its more likely that this is a temporary solution for this vehicle. I think being it is a Jeep, an old school Character LCD and number keypad solution would be fine. Right now the main goal is to work out the software/hardware kinks so that I can set it up in a Mini-van or SUV or whatever we get next.
                            With everyones help here, I think I am back up to speed with what is going on in the MP3Car world again. And boy has it changed! Its SOOOOO much easier than it once was.
                            Some of you guys out there like me, started this stuff when LCD screens weren't even invented yet. they were just a pretty kewl idea once seen on star trek. HAH! Look where we are now? More pics to come soon with the install and visuals.
                            Centrafuse 3.1
                            Garmin Mobile PC
