Hooking audio out to Amp?
  • Hooking audio out to Amp?
    Do I need to connect a Line Output converter (LOC) between the audio out before the Amp? I don't want to try and use inline to RCA cable to hook the PC to the Amp and fry the inputs.
    If I have to hook it up to a line output, how do I connect it? (LOC has + & - inputs for each channels)
    You will be perfectly fine connecting straight from your sound card to the amp
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      Yeah what are you talking about frying your amp?
      Just plug the RCA cable from your sound card into a splitter and then each channel of the splitter into the L and R inputs of the amp.. thats all.. :-)
        great to hear. I wasn't sure if the signal was low enough for the amp's input. If it wasn't then it'll fry or damage the amp. This make wiring it up so much easier.
