Car MP3 control, would this work?
  • Car MP3 control, would this work?
    Just found this... would this work in a car set up?
    Mazda 323F
    Lilliput 7in
    Toshiba Tecra, MapMonkey, DVD, EZ Sync, Roadrunner
    Expensive though, compared with the LCD's you connect to the parallel port, conbined with say a keypad.
    I wouldn't bother with it myself.
    I reserve all rights in connection to each post I author, without exception.
      I have one of these in my room. It works really well.
      Pros: The sound quality is really good. It doesn't take much of a server to support it. (I run it off my 800Mhz celeron. Normal load is about 2-3% and about 23 MB of memory). The server software is open-source perl with an active development community. The server runs on Windows, Mac OS X, and pretty much any linux or unix. The display is really bright and adjustable.
      Drawbacks: No built-in control buttons (IR remote only). You really need to use the server's web browser interface to fully control playlists, etc. At just over 8" wide it's too large for car installs limited to the standard DIN width.
      if you wanted to put one of these in a car all you need to run from the server PC to the player is a crossover ethernet cable. The server could sit in the trunk, out of the way.
      More info: Slim Devices
