Help, Windows Error
  • Help, Windows Error
    HI Guys,
    All was working fine. Went out to the car a couple of hours later, start the car, try to boot the car puter, no go. This is what I get.
    The computer BIOS does it's thing. I get the Windows Splash screen (now I have to choose either safe mode or normal boot because of the bad boots that have occured), then the splash screen again, and then, the Black Screen of Death, with the following written exactly like this,
    While initializing device VKD:
    Windows Protection Error. You need to restart your computer.
    Press any key to continue.
    When I press any key, the computer shuts down.
    HELP, what can I do. What is Device VKD. Can I determine which device is having issues easily??
    Any help, Please.
    Michael
    I remember this from a long time ago. Seems to be you deleted/renamed smartdrv.exe to prevent windows from loading the old 16bit drive chachine progream as it would confilct with the 32bit one present since 95osr2
      Taken from MS site:
      Error Message: While Initializing Device VKD -- Windows Protection Error -- You Need to Restart Your Computer
      The information in this article applies to:
      Microsoft Windows 98
      Microsoft Windows 95
      This article was previously published under Q263318
      If this article does not describe the error message that you are receiving, view the following Microsoft Knowledge Base article to view more articles that describe error messages:
      315854 Windows 98 and Windows Me Error Message Resource Center
      If this article does not describe your hardware-related issue, please see the following Microsoft Web site to view more articles about hardware:
      http://support.microsoft.com/support...hwddresctr.asp
      SYMPTOMS
      When you start your computer, you may receive the following error message:
      While initializing device vkd -- Windows Protection Error -- You need to restart your computer.
      After you receive this error message, you may receive the following options after your computer completes the Power On Self Test (POST):
      Press F1 (or equivalent key) for Setup
      Press F2 (or equivalent key) to load defaults and continue
      CAUSE
      This behavior can occur if the keyboard that you have attached to your computer is not working correctly. When your keyboard does not work correctly, the keyboard cannot be initialized.
      RESOLUTION
      With the computer turned off, disconnect and then reconnect the keyboard.
      If that does not work try using another keyboard to determine if your keyboard is malfunctioning. If it is, replace the keyboard.
      MORE INFORMATION
      VKD is the acronym for Virtual Keyboard Device Driver.
      A multi-function keyboard is a keyboard that includes additional features such as a sound volume control, a mute option, and special shortcut keys so that you can sign on to your Internet service provider (ISP) and perform functions such as "search."
        Thanx for the help
        I will try a different keyboard. I hope that works, and will let you know.
        THanx
        Michael
          Nope, No Dice. Didn't work.
          I then checked the connection at the MB, and it looks like it might be bad. I could probably solder the connection, too make sure they are good, but I need a quick fix. Does anyone think that a USB keyboard might solve the problem. I guess I can always just pick one up and test it, but I was hoping someone might chime in if he knows it WON't make a difference.
          Thanx
          Michael
            Can you disable your keyboard in BIOS? Id try that before dropping $30 or so on a usb keyboard just to test it.
            The Grand aMP3 Project
            Car: 96 Pontiac Grand Am
            Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
              I looked, but didn't see anything like that in the BIOS.
              Also, isn't it a windows issue, so will changing the BIOS to not look for the KB change whether windows attempt to INIT it.
              Thanx
              Michael
              Also, 30 dollars aint bad, if it will work, and if it doesn't, I can return it.
