Which harness to use for Ford Focus 2006? Advanced/Standard?
  • Which harness to use for Ford Focus 2006? Advanced/Standard?
    Hi,
    I just bought one of the all-in-one Chinese 7" 2 Din unit thingos. Just wondering if I will need a standard ISO harness for my car or one of those advanced ones? (I think they have RCA connectors but not sure). The unit comes with both the standard ISO and RCA connectors so I'm not sure which one to use.
    Thanks,
    Sam
    I expect it's this
    http://www.crutchfield.com/p_1207055...e-Harness.html
      Yeah I have been looking at similar ones to that but I would rather not do the wiring/soldering. Maby something like this?
      http://cgi.ebay.com.au/Ford-stereo-I...item3cb12232a4
        You will need to connect all the wires from the harness for your vehicle to all the wires from your headunit.
        If you have issues connecting wires together, you might consider having a professional install your gear.
        How about the Wiki?
          Yeah which is why I was thinking about going for the second option. The unit comes with an ISO harness so it should just plug right in yeah?
            there is no standard connection type in car audio. every manufacturer uses their own style of connectors, so you must connect the wires together from the adapter harnesses to get the correct configuration for your purpose.
            next project? subaru brz
            carpc undecided
              Ah ok fair enough. Do you suggest just wiring the two directly together to crimp some sort of connector on?
                Sorry but I don't quite understand.
                I do realise that each car manufacturer have their own wiring but I thought these wiring harness adaptor converts this into a standard male/female plug that can be plugged into another unit using the same standard male/female plug?
                  the ford-specific connector in your car should be completely different from the chinese unit's connector...
                  you should be able to get a adapter cable for the ford harness+ connector, and the chinese unit should include connector with the wires hanging off it-- you would need to connect those 2 harnesses together.
                  butt connectors are common for this-- just make sure to fully crimp them so they don't fall apart later on. otherwise, i prefer to solder my wire connections.
                  carpc undecided
                    I get what your saying and yes, some companies do the work for you and sell for example a Ford harness already mated to a Pioneer harness but I doubt your going to find one for your puter as stated by Soundman.
                    Also, no offense, but maybe Darque is right: if you are that relucant to do one of the most basic functions of upgrading any radio in a vehicle, should be messing with it at all?
                    Maybe paying someone is the right way for you to go. If you have friends that do this stuff, beer can go a long way to getting help just wait until it's in and working before offering too much!
                      Why not take a quick pic of your Ford wiring harness, then just take the new head unit wiring connector unit to your local auto store (Pep Boys, Strauss, AutoZone, National Auto, etc) or even Best Buy. Look for the OEM style wiring harness, compare it to your pic and then read the wiring diagram of one at the store..
                      That should ensure you are buying the right connector as well as understand what the connections are going to be (those are pretty standard though.. speakers, ground, battery power, starter power, power antennae and possibly an illumination line to control brightness of the display).
                        Lol yeah I don't mind having to wire it but if there is a plug to convert it I would rather do that :P
                          Originally posted by PhilG View Post
                          So this is 2 separate harnesses. Just wondering what the smaller one is for?
                            The crutchfield link shown has an error. I did a quick search on the site for a 2006 Ford Focus and saw a pic for a single wire harness. Pics on these sites are not always exactly what the product looks like. If a harness comes in 2, most of the time it just means they split the power from the speaker leads.. No biggie.
                            The most important thing here is to make sure you have the correct harness and make your connections as directed.
                              The above link is if you have the factory sub woofer, (I should have mentioned that)
                              This link is without factory sub:
