Small problem with the USB HUB
  • Small problem with the USB HUB
    I have a small problem with the USB HUB. There are 2 cameras, GPS, TV tuner, 3G modem, etc. sometimes loses power when the ignition is turned on. I just need to reboot and everything is back to normal. But this problem is very annoying. Are there any suggestions to solve my problems above?
    tangkas_baru
    http://www.mp3car.com/vbulletin/show...onda-cr-v.html
    You may need a PSU with more power...at least that was my problem(solved it with an M4)
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
      Since I noted you have at least 5 USB devices (if I counted right), I assume you are using hubs along side the ports from your computer. Could you tell us the details on those? Are the powered? How many ports? What items are connected too each? Just need a little more details about those to help...
