Cool new motherboard. LVDS built-in!
  • Cool new motherboard. LVDS built-in!
    COMMELL LV-670M
    This thing's almost perfect:
    • LVDS interface.
    • Mobile Pentium 4 (not a big hot desktop CPU).
    • Intel chipset.
    • USB 2 and Firewire.
    • SPDIF digital audio out, 5.1 suport.
    • DiskOnModule / Flash Disk support.
    If only it had digital audio in, and RCA analog audio connectors instead of mini connectors. (I don't get why manufacturers are making these so-called "hi-fi" motherboards that use mini audio connectors instead of RCAs.)
    Main drawback is that this isn't meant to be a retail board, so it probably won't be cheap.
    As seen on mini-itx.com.
    whats LVDS interface?
      Re: Cool new motherboard. LVDS built-in!
      Originally posted by billthecat
      COMMELL LV-670M
      • LVDS interface.
      • Intel chipset.
      Yes, almost...no serial...
      Aura MR62 (F and R)
      My Current MP3s
      IamDefiler.com
        Try to find a US source and price.... This has been the topic of several threads on Sudhian Forums.
        TruckinMP3
        Read the FAQ!
          LVDS means Low Voltage Differential Scsi, but they are using it in the context of video here, so there must be a new meaning.
            almost the same
            Low Voltage Differential Signaling
            2004 G35 Coupe project
              Yea, acronym overload. When I read LVDS I kept looking for the scsi card specs. now we have to specify if its scsi or video
                LVDS=LCD controller onboard in this context. Meaning this board can directly interface with a bare LCD (all you need is an inverter for the backlight).
                  Re: Re: Cool new motherboard. LVDS built-in!
                  Check the specs again. There's one serial port.
                  I don't see it in the picture, so there must be headers for it somewhere on the board.
                    ultim8pc sells these. They are like $280 or something.
                      ouch
                      hefty price compared to our little epia friends
                      gotta buy a p4 also which will set you back another 100 or so depending on what you buy
                      picture doesnt show any serial
                        $280 is better than I would have thought.
                        When you consider that a LVDS LCD controller can cost $200+, it's not such a bad deal.
                          true true
                          didnt look at it from that standpoint since im not looking into lvds lcds
