Best way to control/ interface with computer
  • Best way to control/ interface with computer
    What is the best way to interface with the computer. My setup is that i have a lap top under the seat, it is linked to a desktop in the trunk.
    Basically I want to be able to switch between playlists without having to pull out the laptop. I was thinking a cheap solution is to use a number pad. Will winamp allow me to switch playlists using a numberpad? is there a better way to control it so that i can jump between different playlists or directories?
    winamp will allows you to switch playlists using a numeric keypad if you use blackwinds plugin.
    "if everything is under control, you're not going fast enough!"
      I'm using a cheap 5 $ gamepad and MindTwist (www.MindTwist.com). When you use MindTwist with Instadisc (on the MindTwist page), you can change playlist w/ the gamepad buttons.
      [SIZE=1]'91 Nissan Stanza
      [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
      Car Totaled and i bought a 20G mp3 player
      http://machs-fuel.tk
      a DIY video projector page
