Shutdown Macro from Winamp
  • Shutdown Macro from Winamp
    Since I'm using a ATX power supply the computer will turn off when my windows is shutdown. Is there a way that inside winamp from a numeric keypad send the shutdown command to windows ?
    I don't know about a keypad, but with the IRman plugin for remotes, a button can be programmed to shutdown winamp and the computer...
      Why doesn't someone write one for the numerical pad... And don't ask me, I am a web programmer.... But I will give it a try!
        I am working on a small app. that you can place in the startup menu that will shutdown the PC when you press a selectable keypad key.
        You run the program and tell it what key you want to shutdown with and give it the path to your MP3 player (winamp, etc.) and it will automatically run WinAmp for you when you boot.
        All you would need to do is set it to be the shell on bootup or place it in the startup menu instead of WinAMP.
        At the moment it simply runs minimized, but I may make it a tray application or run in the Win95 control panel if many people are interested.
        Anyone interested?
        --Jason
        http://jump.to/m2pc.
        Jason Johnson
        Yorba Linda, California
        http://www.m2pc.com
        MPC Phase IV - *** PENDING ***
          I would be interested in your software Jason.. Can ya send it to me ny any chance ?
            I'm still working on the program, but it should be ready soon.
            Check the software page on my website at:
            http://www.m2pc.com/software.html
            For updates and to download the software when it's done.
            Thanks,
            Jason
            www.m2pc.com
            Jason Johnson
            http://www.m2pc.com
              Id be real interested Jason. Let me know about your progress.
              thanks
              Aladdin
