Timed kill / timed 12v off
  • Timed kill / timed 12v off
    Im wanting to build something that will kill 12v 1 minute after the key is turned on, but also be able to have an override button/switch to allow 12v continuous with key.
    In this instance to kill 12v to my coil or fuel pump after 1 minute to make the crooks think car broke down.
    Before the flames begin like another forum i asked in, yes its an old car, no i dont have to worry about ECU/ECM etc... Yes i know there are other alarms that are on the market i dont want to use them, thanks.
    Oh and google searches seems like something like this might be used??
    http://www.apogeekits.com/start_stop_timer_k2579.htm
    They make timed relays that will do what you want.
    However this has nothing to do with CarPC's, and that is what this forum is about...
    1.9in x 2.9in -- 47mm x 73mm
      why even let them start the car? my parents old suburban had a kill switch in it that would not allow the fuel pump to get power unless you pressed on a flexible area of the dash that had a switch behind it to engage the relay.. because the fuel pump wasn't running, no fuel was getting delivered, and there was no way to get it to start..(this was on a fuel injected truck. for a older carbureted car, you'll need to investigate other methods..) there are plenty of schematics online on how to do this..(it really just requires a latching relay)
      now just remember-- if you have a super rare/valuable car, it doesn't matter how many theft prevention things you do, if crooks decide they want your car, it will be gone.
      next project? subaru brz
      carpc undecided
        It is hard to design against a flat-bed tow truck.
          Originally posted by 2k1Toaster View Post
          +1
          exactly. sometimes you can get so caught up in designing a top-notch security system, that you forget how easy it is to take the car without having to mess with the security system until they are far, far away...
          i have some ideas to prevent a flat-bed robbery, but they involve hiring a security detail, and firearms
          in that case though, your better off selling the car, because i don't think either is very cheap..
          carpc undecided
            ive done searches, and there are a few posts about kill switches etc,, and nobody crying about their posts not being computer related.....
            Security systems?
            Think about it, a crook is less likely to tear your ride up if the car starts and drives, then in the middle of traffic etc just dies like it broke.
