Where can I buy the adapter cable for a VoomPC (Ampie) case?
  • Where can I buy the adapter cable for a VoomPC (Ampie) case?
    The harness that plugs into the exterior of the chassis is a terrible design and some of the wires pulled right out of it. I don't know of a way to get the wires to go back into there since they were crimped in pretty well so I think I may have to buy a new harness. Does anyone know where I can buy one of these? Canadian preferred but I'll shop outside.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    If I were you I would change your quick disconnect to this ----------> http://store.mp3car.com/12v_24v_Comp..._p/cbl-081.htm I had the same setup on my old voom case which the pins where bent, and used this instead.
      Sold except for one problem. One of the J connectors on the M2-ATX sends a switched signal out to the amplifiers through this harness to turn the amplifiers on. I didn't see this wire in the harness anywhere, is it included?
      My harness has:
      - switched in to M2-ATX
      - power in to M2-ATX
      - ground to M2-ATX
      - switched amp turn on out to amplifiers
      I can't imagine they would make such a great product without including this, it's crucial.
      Ampie Case
      256 MB DDR2 PC5400
      M2-ATX-HV
      2005 Honda Civic
        that appers to just be a standard 2x4pin molex connection. you should be able to locate a replacement at most electronics suppliers (future electronics, digikey, allied electronics, jaycar)
        next project? subaru brz
        carpc undecided
          I'm a retard, you're completely right. I assume this will work?
          http://www.memoryexpress.com/Product...17077(ME).aspx
          or
          http://www.memoryexpress.com/Product...17359(ME).aspx
          Ampie Case
          256 MB DDR2 PC5400
          M2-ATX-HV
          2005 Honda Civic
            it looks like either would work.
            i would prefer to get the second one-- the extension cable. this way, in case it doesn't perfectly match up, you have both connections, and can make your own setup..
            carpc undecided
