LCD doesn't work with Winamp as shell. Help!
  • LCD doesn't work with Winamp as shell. Help!
    I am having a problem getting my lcd to display text (backlight does come on) when winamp is the shell or when winamp is placed in the starup folder. If I open it manually it works fine though. The lcd is a crystalfontz (serial) and the plugin is the serial controler from this site http://henrik.husted.net/ . I also use the irman and it works in all situations. Open to all suggestions. THanks
    Maybe the icon you use to start it normally is running a different copy of winamp, i.e. you maybe have two copies of winamp installed, one with all the plugins etc, and one that don't. (A long shot I know but just a thought)
      Yep, you have two copies of winamp installed.
      try this. Pull up a dos prompt and type "winamp.exe" Then see if it works fine.
      abcd-1
      abcd-1
