MJS USB Audio Selector: "Sorry no UAS found."
  • MJS USB Audio Selector: "Sorry no UAS found."
    I've connected the device, windows has detected it, and the drivers were installed successfully. However, when I attempt to run the standalone application to verify everything works, it doesn't seem to find it. In case someone can point out something I missed, I took a couple of screenshots:
    Note: I do also have the HD radio USB cable connected as well. Not sure if that could complicate things (I imagine it wouldn't, but thought I should mention it). Any help appreciated!
    My Worklog: 2008 Mini Cooper + Mac Mini
    Also, in case it helps, I'm running Win 7 (32-bit) and have the USB audio selector connected to a passive USB hub.
      you might need to try it directly off a motherboard usb port.
