Webcam HD-5000 autofocus disable
  • Webcam HD-5000 autofocus disable
    If anyone wishes to “permanently” disable autofocus on the MS HD-5000, there is a way.
    You do not want autofocus in a car, especially with a camera looking through the screen, and the HD-5000 has a problem with autofocus as it is. On top of that it will revert back to autofocus any time +5v USB power is removed.
    I kept coming back to this camera because it is far better than the Logitech 9000 in picture quality and in the real FPS that they will actually do, also because of its low cost and size. I run 720 x 1280 30FPS.
    Of course you void the warranty and there is always the chance you could kill the camera if you do something wrong. Still at around $30 to $50 for the camera it’s not too big a loss. It really is a great little camera.
    The first thing to do is to turn off autofocus in software and move the software manual focus bar all the way to sharp distant focus, now unplug the camera, this ensures the focus motor is in the correct position.
    UPDATE: I have rewritten this intro to the thread as thanks to input from BADMOPAR you can easily pry the front plastic glass and trim from the camera face.
    There are two screws behind the trim, remove these screws and the housing comes apart easily.
    The PCB with lens is screwed to the back part of the housing and the lens is screwed to the PCB.
    There are two solder tabs on one side of the lens, I heated the tab closest to the edge of the lens and used a pin to pry it away from the PCB solder tab, the metal connecting tab is very flexible and moved easily.
    I reasoned that this could have been the supply to the Autofocus motor and it appears I was correct.
    You need to be careful not to splash solder on to the small SMD chips near the tab as you unsolder it. I used a bench magnifying glass to unsolder and check for any solder spray. Make sure there is no dust or rubbish on the lens or inside the front housing and reassemble.
    Mine is working great, no more stupid autofocus.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Have you asked Microsoft to change the drivers ? I'm afraid that in my case my camera will die.
    I don't wanna be a product of my environment.
    I want my environment to be product of me.
      Not a driver issue. I don’t use the MS software as its utter rubbish. A few folks have found, as I have, that installing the supplied SW will cause the camera to report a drastically reduced max resolution to programs like MiniCam. Even the MS program for the camera control will not keep the setting. IMHO It’s a hardware issue and the flaky hunting autofocus is also most likely a HW issue as a firmware update changed nothing.
      It’s a nice thought but good luck with MS changing anything for anyone. This focus issue is all over net and has been for a long time.
        I have talking about drivers not software, I don't use the Microsoft software too. Maybe some registry changes could be the solution, but I don't know, I'm not a programmer.
          Registry settings and the driver are not the problem.
          The MS software (which we don’t use because it’s useless for any decent recording) should talk to the webcam when it sees it and reinitialise the camera, however it doesn’t, but its a moot point anyway as everyone is using 3rd party recording software, nothing you do, short of writing an application to talk to the camera on resume from standby/hibernate and/or install/removal of the camera from the port and force it into auto mode is going to work, that would cost more than wrecking a camera.
          This hardware mod costs nothing (unless you break the camera) and only takes a few minutes, and autofocus can never enable again unless you resolder the wire.
          When I get a chance I will take some pictures and show how simple it is.
            It would be very appreciated.
              Having opened the first camera and had a really good look I now know that the case is actually screwed together at the bottom. The screws are inserted from “behind” the front panel clear plastic and trim.
              UPDATE: I have rewritten Post to reflect new info on opening thew case. You can easily pry the front plastic glass and trim from the camera face. There are two screws behind the trim, remove these screws and the housing comes apart easily.
              HD-5000
              Unsolder this connection to the Lens housing. I placed the camera mount in a small vice to keep the camera stable and used a long pin to prize the connection away from the solder pad as I heated the pad with a soldering iron.
              Connection unsoldered. Now check for any solder spray and brush it off.
              This is the second camera done, about 5 minutes and works perfectly. Just remember to set the autofocus to off and move the focus to distant in software before unplugging the camera and doing this mod.
              Again, you void any warranty and you do this mod at your own risk!
                I got one of these coming in the mail. Thanks for sharing the hack.
                  Thank a lot Mickz! Your guide would become quite handy even though my camera is LifeCam HD Cinema.
                    You don't need to drill holes anymore
                    Simply use your fingernails to remove the front plastic glass.
                      Thanks BADMOPAR, I don’t have the nails anymore to do that, makes the mod pretty straight forward now, although you need a steady hand and good eyes to unsolder the tab.
                      I actually wonder if the tab could be cut with very fine wire cutters, save any solder splash and potential melting of plastic if you’re not good with an iron or don’t have a fine solder tip.
                      UPDATE: I have rewritten the thread posts to reflect you info on the case, it should less confusing now for prople doing the mod.
                        And I was goddamned right. The system see my camera no more
                          I have modified two of these cameras and both are perfect. As an electronics engineer I know what each component on that PCB does and how this camera works, I can say that the only way you can stop this camera working is to splash solder over the PCB components. A fine tip soldering iron and a little heat is all thats needed to pry the tab away from the PCB. That action alone cannot damage the camera. Have a real close look over the board. Make sure that the two solder pads on the PCB have not joined together when you unsoldered the outer tab.
                          Because of the focus problem I was “real rough” with the first camera as I was going to junk it, I still couldn’t kill it.
                            I don't wanna blame you Mick.
                            Here is closer look on my camera. Tell me what you think.
                              Yes, I know it’s frustrating when something doesn’t work, however there are a few problems here.
                              Looks like way too much heat or the soldering tip was way too big. The tip of iron should only be applied to the base of the solder pad as the tab is levered away from the pad. It looks like the soldering tip may have gone through the side of the image sensor housing, but it’s a bit hard to tell from the picture. Providing it didn’t short anything out, it may be ok. There also appears to be a lot of solder spray over the board.
                              I would get a big magnifier so you can see any solder bridges, and a tooth brush to clean the area around the solder pad and components.
                              Once that is done, a picture taken from directly above the board and a close-up of side of the housing may give me a better idea of the condition of the PCB and components.
