Flush mount usb extensions
  • Flush mount usb extensions
    EDIT:
    Good Afternoon,
    I purchased a panel from an online vendor and had holes fabricated to fit generic USB extensions. The cables fit the hole just fine, but the problem is they don't stay in place. There is nothing to keep them from falling back through the hole after a the slightest pressure.
    Therefore, has anyone found a product that allows a USB cable to be mounted to a surface such as what I have purchased and seen in the picture below?
    Thanks a million!
    Over a year later I guess it's true...a carPC is NEVER complete
    2002 Mustang CarPC
    Bump
    2002 Mustang CarPC
      Maybe something like this?
        The extension I have now actually protrudes through the switch panel.
        With something like this, the item that I am plugging in would have to be the one which protrudes through to the underside of the switch panel where the head of this extension would be. It would work, but I'm going for a more custom/"finished" look...
        If only the head of the extension sat ABOVE the mounting tabs...then it would be perfect.
        Thanks for the reply!!! I appreciate the idea.
        2002 Mustang CarPC
          http://www.l-com.com/item.aspx?id=28964
          Expensive, but REALLY nice. Doesn't quite fit what you bought, but tbh, research before purchase, always :P
          RevFE
          My Shop
            can't you mount the headers flush to your trim panel?
              Now that looks nice...
              Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
              7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
                So that the plastic tabs on either side of the female port would sit on top of the trim panel? The holes created by the vendor barely fit a usb plug through them. I would have to have a new part ordered or hack up mine
                No kidding, but $60 bux for USB ports?? haha. Maybe I will order one and see if it even fits in my slot. But yes, they are sexy!
                2002 Mustang CarPC
                  Why not use the USB cable in post #3, and glue it to the underside of your panel? You can gently sand/cut some of the plastic from the mounting hardware so that your USB port sticks up a little bit through the hole, and you can use a plastic epoxy to glue it to the panel. After 24 hours, those babies won't be moving at all.
                  1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
                    [QUOTE=Archy88;1456937No kidding, but $60 bux for USB ports?? [/QUOTE]
                    How many do you need? They look to be $10 each. I would only need one or two for charging devices, or plugging in a thumbdrive for easy file transfers.
                    Most likely I'd use WiFi to transfer files anyway, and the I-Pad won't charge well off of a normal power port anyway, so one port for misc. uses and one wired to a high power USB charger, and I'd be good.
                    The downside to doing a bunch of work to custom fit a cable plug in to a bulkhead is that if you wear it out, you've got to go though that all again.
                      That is honestly a fantastic idea. I could actually cut the tabs off completely(I think I would need that much depth to sit through the panel) and there seems to still be a surface area around the plug for some glue.
                      Thanks for the reply. I've tried using wifi but I have always ended up going the route of a flash drive on my way to work, etc. Before the custom panel, I had a 4 port usb hub which had a usb wifi dongle, a micro usb cable for charging my phone, and then two ports for flashdrives, etc.
                      Unfortunately, my external harddrive requires more power than the usb hub can provide for large music transfers. This is where the 5th and 6th port came into play. I ordered two 6ft extensions which would plug directly into the carPC for this use.
                      In the end, yes...I definitely have way too many ports lol. But if I ever want to add a bluetooth dongle, etc I won't have to worry about taking apart my dash. But what I should have done was order a USB hub that is used to surface mount on a home office desk and had that plop into the panel. I guess I tried to get too fancy..
                      2002 Mustang CarPC
                        Originally posted by Archy88 View Post
                        EDIT:
                        Good Afternoon,
                        Thanks a million!
                        Blue Seas dual USB charger in the 2nd row ash tray.
                        I want to do something similiar, but I just want to have the USB ports flush mounted without that housing around it... So you just see the usb ports only, for a more stealth install. ANy ideas???
