External sound cards, what one did you use and why?
  • External sound cards, what one did you use and why?
    i am having trouble with a external sound card.
    I woul dlike something that i can use 24bit, usb to a 4 volt rca... however the ONLY device i can find is the logictec with 1 preamp.
    i was always told that if you chain amps off via pramp output to input will degrade the signal.
    thanks for all you help .
    Wolf
    ty for the approval mod.
      ha, never seen anyone thank for that your welcome
        i am a IT nerd, i know what goes on in the background
          ^lol
          i use a esi gigaport hd. i use it for the 8 outputs-- that is it.. the sound quality is good, the output level is horrible..
          next project? subaru brz
          carpc undecided
            Why do you want 24 bit audio? What kind of music files will you be playing?
              I use this one (16 bit) Tascam US-100. Great improvement over my TabletPC meaky soundcard. Never once gave me a headache or any ground loop issues. Great range, balanced inputs if you need, sweet sound, and no problems with hibernation/resume/hybrid sleep. Very happy.
              If you want 24bit, USB too, I would go with these: Tascam 122mkII and 144mkII or the new US-200.
              Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
              Skin: MetroSex on the Beach preview
              07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
                I have had great success with this http://us.store.creative.com/Creativ...B0044DEDCA.htm unit. Some talk about power on thump and other various issues but I have not experienced any significant problems with it. Just don't install all of the software that comes with it, you'll need a second hard drive to hold it all .
                  i am some up of a audio buff, i made "laptop" that will interface with the car's computer.
                  i then wrote a program that will pull images from the freeway camera's as i am driving to work so i can see my way
                  the only thing i have yet figured out is the pc to amp .... i am not going to use a head unit, but a touch screen.
                  i play rap, oldies, and some head banger *****.
                  will be playing mostly 320kbps wma files.
                    i have this unit, but like i said i have always heard about dasiy chaining rca ports, will lost the function of l/r and degrade sound.. so i wanted a unit that could have 3 pre-amps just like a head unit.
                      I know that modern desktop mainboard D/A converters have improved vastly over the last 15 years or so, some used to be truly awful, these days they can be pretty good. I don't know about modern tablets though, do they still sound fairly cruddy?
                        I'm a bit slow on the uptake, so I'm still not quite sure what you are after. Are you able to do some kind of diagram?
                        I'm not aware of any external USB soundcards that have four or more outputs that do not require extra power. Something cheap like the M-Audio Fasttrack Ultra might do what you want it to providing you can give it an extra 5 volts, you could probably configure the control panel to output your audio on all 6 outputs if you wanted. Like the Tascam units the outputs are balanced +4V so if you have earthing problems you can just drop the earth and wire the cold to the RCA shield.
                          my experience with most of these sound cards is that all require extra software to have more level or l/r control over each output.. my understanding is that windows does not provide this at all..
                          carpc undecided
                            Not necessarily, it depends on how the drivers are written. Some have outputs that show as different devices eg: 1/2, 3/4, 5/6 etc in the windows device manager, and so it is possible for different programs to use different outputs without using the control panel for that particular product, but the main stumbling block that I have encountered is that they are designed for use with audio recording / editing programs and thus can not be used, for example, for 5.1 surround sound.
                            Having said that I'd still steer well clear of these kinds of things for car setups and use either onboard audio or if the quality is not that great then go to some kind of USB stick style stereo input / stereo output thing, like what the Andrea directional microphoes come with.
                              i though i posted 2 post, idk where they are....
                              the build i am doing is of a laptop i built.
                              i want to interface with the laptop to my 2 amps..
                              1 4channel
                              1 mono
                              however i would like to have 3 pre-amps out. this is my problem. i cannot find any external sound card that has more then 2 pre-amps.
                              i was always told that chaining the rca's from amp to amp will lose sound quality.
