Mounting computer in a trunk
  • Mounting computer in a trunk
    Are there any issues to be aware of when running DVI and USB cables over a distance of, say, 12 or 15 feet from a trunk installed computer to a monitor in the dash?
    Run the signal cables down one side of the car and power cables down the other side to minimize the possibility of EMI.
    Some say that high-quality cables are better than cheapie ones. Some use cheapie cables with no problems. Be prepared to try different cables for the best results.
    How about the Wiki?
      Your monitor will function just fine if you stay at or under 15 ft. For other devices, however, at that kind of length you'll need a powered hub on the other end. The max length of a USB cable is 5m (for full speed devices) or 3m (for low speed devices) - USB devices won't get enough power if you go longer than that without a powered hub on the other end.
      1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
        ^^^What they said.
        Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
        Skin: MetroSex on the Beach preview
        07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
          Is there a common equation for voltage and current drop over a wire length?
            There is an equation, yes. V = (25 x I x L) / CM
            This site explains it: http://www.stealth316.com/2-wire-resistance.htm
            It also has a handy calculator for voltage drop.
            How about the Wiki?
              ^ Thanks!
