USB panel mount
  • USB panel mount
    I was looking at installing a few USB panel mounts in a removable plastic insert in my car however the price of the USB extensions is like 10 bucks for 2 feet.
    Was thinking of using the Rear panel mounted ones. They are basically the same connections only it plugs directly into mb, and is short. Is it viable to splice into this cable with something like a spare Ethernet cord to add on the extra couple feet or would it lose signal?
    http://mobile.buy.com/ibuy/Product.aspx?sku=216778197
    Something like this. Cheap and 2 plugs for one buy
    Here is what I am using, they are about $5 each and just fit in a drilled round hole. You add your own usb cable to the back side of them.
      i have used cat5 cable to extend them, just keep in mind that usb is limited to about 3m unpowered.
      next project? subaru brz
      carpc undecided
        Good I was only planning to run em a few feet. Also I found like 4 of the double USB mounts for back of a pc. Yay already owned mods
          What?
          15ft, $6.85 (free shipping for me); there's also an "active" one, with an inline amp (for devices themselves that requires little power) for $.85. I have used both, with great results (as long as you don't power an usb camera or GPS, everything else worked).
          Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
          Skin: MetroSex on the Beach preview
          07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
            Monoprice.com has the best cable selection for the cheapest prices. I always check them first when I'm buying any cables, be they HDMI, DVI, USB, or CAT-5e, or any other cable for that matter.
            1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
              Originally posted by RipplingHurst View Post
              What?
              by the expensive part, i didnt mean a normal usb cable. meant more along the lines of the special ones that have a mounting part <similar to what i linked> and of decent length.
              so much money wanted for just that little bit of plastic to mount it. Oh well I found some of the rear panel mounted USB's that plug directly into pins on the board so I will attempt to extend those a few feet so it can reach from behind the dash to center console.
                Link? Amazon has free and fast shipping. And best return policy. But I agree, monoprice is very competitive for some things.
                  15' USB extension cable, $1.79.
                  http://www.monoprice.com/products/pr...seq=1&format=2
                  Monoprice isn't competitive - everyone else tries to compete with their prices.
                    Where do you get those USB plugs Phil?
                    Sound Stage
                    Eclipse|MTX|Infinity
                      ^ try checking industrial parts sites like mouser, digikey, etc.
                      carpc undecided
                        You can get them for cheap on eBay as well. Just narrow your search to US only (if in US) and select free shipping if your determined to get free shipping.
                        2' USB Extension. $1.50 after shipping...
                        eBay links don't work here for me so, can't post the link.
                          Any idea what you call them?
                          Sound Stage
                            Try here:
                            http://www.mouser.com/Search/Refine....user_Wildcards
                              Here is the manufacturer and the piece:
                              http://www.neutrik.com/en/multimedia/usb/nausb-w-b
                              Here they can be sourced right from the GTA and mailed to you:
                              http://www.avshop.ca/wire-cable-conn...thru-blacktype
