Got a sweat deal on a Epia 9000
  • Got a sweat deal on a Epia 9000
    I went to Fry's today (for those of you who haven't heard of Fry's it is like heaven for all computer nerds, the stores are bigger then costco and sell everything electronic. There computer section alone is usually the size of a circuit city and they carry just about every obscure part known to man.)
    Anyway, they were all out of Epia M's except for the display model. They apparantly had a sale on them for 120. Since I was getting the display model they knocked off 20 bucks and also since there was damage to one of the locks that holds the ddr in they knocked off another six bucks. So all told I got a Epia M 9000 for 94 bucks. Of course I still have to test the thing to see if it works.
    I ordered the powersupply from Mini-Box and plan to be a guinie pig of sorts for you guys and hook it right up to my cars electrical system. If it blows it blows, it is in the hands of the computer gods...
    Anyway, I can't wait start to work on revision 2.0 of my system. I plan on moving the whole computer from my trunk to a double din case and have it work like a regular slide in replacement for a stereo.
    My mini-box supply died when I pulled out of my driveway, but the guy there says it shouldn't have so they are replacing it under warranty.
      putting your entire computer into a double-din slot the size of a radio will be quite the task... There really isn't a lot of space in a double-din slot to hold everything that you're gonna need for a carputer. How do you plan on accomplishing this?
      And as has been discussed to death already, hooking up the mini-box directly to your car's electrical system is a BAD IDEA no matter if it works for a little while or not, you're gambling and sooner or later it will fry your equipment and cost you $$$$.
      What do you plan on using in this computer?
      IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
        Where did you buy this, what guy said this and did you tell them that you wired it directly to your car's electrical system?
          Sorry I haven't responded, I haven't been on line for a while.
          First off the powersupply, yeah you guys are probably right, I could end up smoking all of this. However I read this faq on mini-box's website regarding their 60watt power supply and using it in an automotive setting. Their response (which you can read in the link) was basically that the power supply can handle anything from 10-14 volts without problems.
          http://www.mini-box.com/faqpw60.htm
          As for getting everything into a double din space it was tight but doable. My system only consists of the motherboard, harddrive, and powersupply.
          One thing about the car I have (a 92 Nissan Maxima) the dash was almost designed for a carpc. Everything just worked to be able to put the whole motherboard right in the dash.
          I will take the system out of my car in a couple of days to build up the software (I'm stilling waiting for my power supply to power it) at which time I will take some pictures for you guys.
            your motherboard is smaller than a radio footprint?
            yeah pictures would be nice to see.
            Long live the Maxima! I've got a '87 in my garage that's rusting to hell because I haven't done anything on it for a while. it needs a lot of work and I just don't have the time
            A lead acid battery doesn't put out 14.4V when fully charged (12.5V maybe), but while the car is running it puts out that much. Their solution is to put a pair of diodes in series to drop the voltage by 1.5V, which isn't a great idea, you might as well just use a linear regulator, that would be a lot better for your system in the long run.
              I'm not sure about the actual dimensions of a radio, just that I had almost ten and a half inches of depth to work with which is probably more then most people have to work with. I will try to take some pictures of it this afternoon so you guys can get an idea of how I did it, although it isn't anything special really.
              Also, I know it has come up before but where do you pick up the linear regulator?
                any electronics store or online in a place like www.partsexpress.com or www.digikey.com
                  Putting a mini-itx in a DIN slot is possible. They mini-itx is 6.5" square and a din slot is 7"wide and 2" tall. the mini-box is in a 1U heiht which is 1.75" tall so in a din you get an extra 1/4".
                  From the page on the mini-box site it doesn't say anything about having anything on the input (see link above). I stuck a linerat in front of mine for now but want to do something simpler. I'm thinking a 14v zener across the input should be enough.
                    Right, but with a hard drive and power supply it'll be really tight, especially if you wanted to put a CDROM in there too.
                    Sure it does... Here I'll quote it for you:
                    Q) Can I use this DC-DC converter with a lead acid battery?
                    A) Lead acid batteries can produce 14.4V when fully charged.
                    Our DC-DC converter was designed for 12V operation, however, it will work at 14.4V without any problems. You can also put 2 diodes in series with the DC-DC converter to drop the voltage by 1.5V or so.
                    Additionally
                    Q) Can I use this DC-DC converter in a car?
                    A) Cars can be nasty enviroments. If the voltage will be in between 12-14, things will be fine. However, cars can produce anywhere from 5-18V, especially when using a weak battery. Again, few diodes should drop V(in) by 1-2 volts
                    any regulator is much better than a diode, as it will provide a much cleaner and constant voltage to the PSU than a simple diode will. Additionally using a diode or two you won't be able to use the computer with your car turned off at all. If you use 2 diodes to drop the voltage to 13V while running, when the car is turned off you will be at max 11V, and quickly drop to a 9-10V range, which is far below tolerance for any 12V devices. A switching regulator is by far the best choice, second a linear and then a simple diode.
                      Just to add my 2 cents, them saying that all should be well seems a bit negligent/ignorant, as they're assuming that what ever runs off the 12v rail can deal with +25% (~9-14.5vdc) the ideal input voltage, as my understanding of the psu is that the 12v rail is what ever the input voltage is.
                      -Nick
                      _____________________________
                      www.mp3vw.com
                        What exactly will be running on the 12volt rail on a system with just the epia motherboard and harddrive? I guess the harddrive if a 3.5 might run on 12volts (I'm not sure about this), but what about a 2.5 aren't they running on 5 volts?
                        Also, I'll be taking the system out of my car tommorow so I will take a bunch of pictures if I get motivated. Of course there isn't much to see as I'm still working on it.
                        I guess I will go find one of those linear regulators, no sense in risking something if I don't have to...
                          They are being negligent, but that's why they are making their "inverter" which is essentially just a power regulator.
                          3.5" hard drives use 800mA-1.5A of 12V (typical) and 350mA at 5V... 2.5" hard drives use only 5V, usually 500mA-1.2A.
                          The motherboard itself probably doesn't actually use any 12V, so only your hard drive and CDROM will be problems with 12V. You can get both that run off of 5V and be fine, however they are much more expensive.
                            If you do a DIn sized you have to use a laptop HDD, a regular 3.5" will not fit. Thats what I'm doing with mine. The guy at mini-box says you can add diodes but does not say its necessary. I have been e-mailing back an forth, he says that since I'm using a laptop hdd the 12v is not critical and that the mini-itx board can handle the varying 12v. I did notice that I had a lot of alternator noise connecting it diretc though. I was taking about putting a zener doide so as to not drop the voltage down. Remember zeners do not connect in series with the line, they go in parallal with the supply and shunt the extra volatge to ground so you don't need a big zener that can handle the full current load of your system like you would if you put a regular diode in series with the supply or even a linear reg. Basically i'm biulding a small surge supressor like what you would plug your home computer in.
                              Just to clarify, I built a double din case that houses an Epia M motherboard. This case has plenty of space for everything that I think I will be needing. I have an old 3.5 harddrive I was intending on using but since it will be on the 12volt rails I might have to rethink this strategy.
                              It sounds like all I have to do is stick with the epia-m and get a laptop harddrive (which I do have one floating around here) and then I can pretty much ignore the 12volt rail.
                              I might just use the old 3.5 harddrive until it dies and then purchase a laptop harddrive when I get some more money to play with. Since the 12volt rail only powers the motor it seems plausible that a 10 to 15 percent increase involtage wouldn't automatically cause this thing to fry itself. What do you guys think?
