Two switches into the 2 pin mobo on/off?
  • Two switches into the 2 pin mobo on/off?
    Hi guys,
    Tweaking one of the carputers over the winter. It has an opus 250 power supply. The power supply has a two wire lead to connect to the mobo to turn the PC on and off. I would like to tap into that wire and run a second momentary switch. Tried using a relay, was not very good and want to use a different method.
    Is this possible? or any suggestions other than a relay would be appreciated.
    Sound Stage
    Eclipse|MTX|Infinity
    completely possible-- my setup has a remote mounted power and reset button..
    just use a N.O. or Normally Open momentary push button. just connect it to those 2 wires(i soldered a spare 2 conductor cable onto the dc-dc's power button wires), and it should work just like you need it to.
    next project? subaru brz
    carpc undecided
      Thanks soundman, glad you are around to answer everyones questions.
      Sound Stage
        just be sure to return the favor occasionally
        carpc undecided
