What should I use for this application?
  • What should I use for this application?
    I am needing to put together a 12 volt pc for a very limited purpose and I am looking for advice on the simplest solution that will work for me.
    I am remodeling a former prison transport bus into a party bus. We are installing an Alpine system in the bus to allow music from iPod, etc. as well as DVD playback, etc. We are installing a couple of flat screens as well. Since the majority of the time we will be playing music only, I want to have some music visualizations on the tv sets to add ambiance. It looks like the best way to go is Soundspectrum G-Force in standalone mode.
    http://www.soundspectrum.com/g-force/standalone.html
    I will just run audio in from the audio system and connect it to a second input on the tv sets so we can have the visualizations running on the screens.
    That's all this will ever need to do. I want something that I can ideally run without an inverter and just turn on and go. Want to boot straight into G-Force. No keyboard or other input attached once configured. Set it and forget it as much as possible.
    Video card is probably a factor. What would you recommend? Thanks for any advice.
    Sent from my iPhone using Tapatalk
    You would need just a basic small pc with on board video and a dc-dc power supply or a small laptop since all it would be doing is visualization. Then just set the software to start when pc is booted.
      Is there anything along the lines of a Mac mini that would work. I was thinking of something that would boot really quickly.
        Intel Atom w/ the ION chipset. An SSD for fast boot.
        How about the Wiki?
          What about shutdown when power is killers without corrupting the drive?
          I am here: http://maps.google.com/maps?ll=38.874164,-86.036610
            You should read the FAQs about power supplies, specifically the intelligent power supplies.
            How about the Wiki?
              Thanks. I did just that and have a Via VE-900, ram and an M2-ATX on the way.
              I am here: http://maps.google.com/maps?ll=38.962219,-85.903535
