Reducing core temp
  • Reducing core temp
    My processor is running at 54C idle in my home well ventalated....with a house fan pointed straight through the vent (it is the same temp without the fan as well)
    [email protected]
    [email protected]
    [email protected]
    I came across something in another forum where this guy found a tool to reduce the temp of the core considerably, but when I went to find this software it was no longer available, this is what he said:
    By using RMClock, I was able to:
    1) Reduce the AMD Neo X2 CPU multiplier from 7.5 to 4 resulting a CPU running @ 800MHz when in idle mode (most of the time on an HTPC)
    2) Reduce the temps from 72 C to 49C resulting less fan noise
    3) "On Demand" power-up (from 800MHz to nominal 1500MHz by steps) when playing games, music, surfing,...
    Does anyone know of any other reliable and reputable software that can accomplish this? I can only imagine when I get this in the car the temp is going to go up by about 10C.
    you can download the file from here SNO
      Have you looked up normal operating temperatures for the CPU/GPU/Chipset? It's entirely possible that 55C is a perfectly normal operating temperature. While some processors throttle when they get hotter than 60C, others don't care. It being a mobile chipset, I suspect that it can withstand a lot more heat (though it should also produce less heat, for the same exact reason)
      My Project: All-in-one Double Din Unit
