Help a newbie. Which system?
  • Help a newbie. Which system?
    Seems like this is a fairly technical forum, but I'm hoping someone can answer some basic questions for me.
    I have a Mercedes A-Class with a Blaupunkt front loading CD player (factory fitted). I want MP3 in my car but I don't want to change the CD player. What would be a good off-the-shelf system for me to invest in? I like the idea of an FM transmitter as I guess it would need no wiring. Is this a good way to go?
    All replies gratefully received.
    I would do a search through the forum, as most of the questions you asked have been covered in the past. Also, if the factory unit offers CD Changer control, I would contact either Blaupunkt or Crutchfield to find if the standar Blaupunkt aux input adapter would work with your head unit. Also, if you are just looking for a prebuilt box, then check out www.phatnoise.com They are supposed to be shipping a unit this fall that will interface with most factory head units with changer control.
    Good Luck! http://home.earthlink.net/~avgeek
    [This message has been edited by AVGeek (edited 08-07-2000).]
    KG6OQD
    www.americansandassociation.org
      Thanks AV, that seems to be an ideal setup for me
      David
