Lighting question
  • Lighting question
    Maybe a stupid question, but can I send 12VDC to a 120VAC lamp (http://www.allelectronics.com/make-a...P-AMBER/1.html)? If not can someone point me to somwhere like mouser.com and allelectronics.com? Thanks.
    nope, not gonna work.
    try to look for led versions.
    what are you looking for in the indicator? color, size, etc..
    next project? subaru brz
    carpc undecided
      Yeah, I looked at the led, just didnt like how they looked or fit...at least between these two shops. I want an led/light that I can drop into place and seal that would sit realatively flush, rather than me pushing it up from behind. color: any four colors, size 4-10mm I guess, less than 30mm deep.
        Geez Soundman, of course he can send 12V to a 120VAC light. It might not light up, but it might get warm.
        Or use an inverter...
        But that's a neon indicator so it won't even get warm - it definitely needs an inverter.
        I can just imagine someone buying an inverter to power a $1.50 light. At least that might save the inverter itself needing a power light...
        Champak - just search for 12V indicator lamps, LEDs or bezels. There are hundreds of variants with different mounting options.
        And they don't flicker like those neons (unless that's your preference).
          Thanks, I decided to just go with http://www.allelectronics.com/make-a...RED-LED/1.html, seems like a decent light and should match my accents. How dol I figure out the amp max for the light so I dont tap into the wrong power line?......or do all wires carry 12V so I dont have to go the complicated route I was planning on.
          Side note, has anyone used this or something like this? How does it make out in comparison to electric tape? http://www.allelectronics.com/make-a...ER-TAPE/1.html
