what do i do with this?
  • what do i do with this?
    now that I got this, how do I hide this? sorry for the large image.. and its sideways
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Shoulda bought a http://www.scantool.net/scan-tools/p...bdlink-mx.html
    Or you could get a http://www.scantool.net/accessories/...1962f-6ft.html
    RevFE
    My Shop
      the first one is nice.. but i do not have an expendable budget and the second may not work as the little cover may not close... I might have to push the OBD port back or something...
      CarPc
      Project "Driver"
      Planning [99.9%]
        my gut reaction to the thread title is "give it to me."
        but i guess if the first option doesn't sound so good, you could also try to unbolt the obd port and tie it up elsewhere below the dash..
        next project? subaru brz
        carpc undecided
          u can "push" the odb connection backwards so it disconnects from its housing.
          By trinybwoy at 2012-04-26
          hope that helps
          trinybwoy
          2006 Mazda6 Carpc
          2008 Acura TSX Nexus 7
            +1 agreed, this way it makes it easy to restore back to factory and allows you to use that section for a more useful interface.
            otherwise you can also make a small extension but unscrewing the plug is quicker
            2004 Holden WL Caprice Auto GENIII
            Base System = Raspberry Pi
            Everything else is pending for now as switched from a Mini-ITX setup
              Just so you know, they check your OBD port for tampering when you go in for an inspection. When I went in for mine, I told the guy I have an onboard computer that connects to OBD. He told me to leave, disconnect it, come back and not mention it to him As long as you can restore it to its original condition, you can push the port in and hide the ElmScan unit that way, but I'd triple check that it's reversible.
              My Project: All-in-one Double Din Unit
                Thanks trinybwoy
                I would believe the only time that port would be used is once a year for inspection. I think on my car ..the plug clips on. As long as I don't break the clips I should be ok
                CarPc
                Project "Driver"
                Planning [99.9%]
