Troubleshoot CarPC - Faulty Hardware.
  • Troubleshoot CarPC - Faulty Hardware.
    I Apologize if this is the wrong section for posting. I didn't see a Carpc / Troubleshooting/Diag section so..
    Figured Ill message you all to pick at your brains and see if you can figure anything out.
    Anyhow my CarPC is messed up. I’m sure it’s hardware failure, I’m just trying to decide which component has went bad.
    A week prior I started getting frequent lockups and BSOD. Every BSOD was different, from ACPI compliance, to Page Fault in Non-Paged area etc. All bsod didn’t point to anything but faulty hardware.
    At first I was thinking it was the SDD or Bad Ram. I’ve determined it’s not the SDD, because I have tested and swapped with a laptop hdd and experienced same issue. I don’t believe it’s the ram although could be.
    I am now leaning on faulty P/S or motherboard has gone bad. By motherboard I mean the on board Video.
    This following link is another user who is kind of experience a similar problem.
    http://www.techsupportforum.com/foru...en-413309.html
    Attached is screenshots so you can see what I am experiencing,
    Click image for larger version
ID:	2309258Click image for larger version
    Click Video Link
    My bet is that it’s the P/S gone faulty, I plan on this weekend taking it inside the house and plugging up a standard ATX power supply and powering it up, IF it powers obviously it’s the P/S if I have the same problem it’s the MOBO. I doubt it is ram, although I don’t have a compatible machine that’s DDR2 to test it in though.
    Thanks for your thoughts, your input would be nice before I start ordering parts!
    Hardware is :
    Zotac 8200 w/AMD x2 BE 2400, 32GB OCZ SSD.
    2GB of DDR2
    does it display that every time? or just sometimes? and does it do it while parked, or only while you're moving?
    i've had a similar screen on my install-- it's due to the vibrations constantly unseating the ram. my most recent try at a solution was to fold over a towel and stuff it under the board to give the ram slot some backing force. so far, i have not had a issue again, but i haven't ruled it out yet..
    next project? subaru brz
    carpc undecided
      I would bet on Ram as the problem here your PC is powering up and since its on-board video it is using the ram on the PC and would also explain your lockups and bluescreens as well SNO
        Well guys, Brought the box inside hooked up a standard atx and it booted right up.. MAde me believe it was the P/S.... I then noticed I was connected to the VGA display port; In the car I connected to the DVI port with a HDMI>DVI cord. I Then tried to plug up to the DVI and got no video inside the house.. SO now I believe the issue is a BAD DVI port, which isn't to bad. I'll take it out to the car and confirm tomorrow.
        Thanks for your input, I was thinking ram as well, power is obviously getting there.
          IT does display every time.
            you were right.
            Issue ended up being Bad seated ram I believe .. totally weird. Thanks soundman98 for your time/thoughts.
              no problem-- now that it's happened once, i would expect to see you have the same issue a month or 2 from again, at least until you do something like i did to reinforce the ram slot(took me almost a year to get to reinforcing mine )...
              carpc undecided
                Yes, I am going to get to reinforcing... Before doing that I'm trying to get money together to build an i3 rig... Adds up, but parts are getting cheaper and cheaper by the day.
                  i paid about $400 for a 120gb ssd 2 years ago now that same drive is almost $1/gb......
                  carpc undecided
                    yes prices have dropped..
