What type of fuse should I use
  • What type of fuse should I use
    What type of fuse should I put inline with my psu ?
    More info about your PS would help...
    Usally it is in range from 5-10amps if its a DC convertor...
    I use 5Amps as the DC convertor im using is quiet effiecent and doesnt use more than 3amps to run the whole system!
    Fosgate
    Fosgate
    System Comp V3 - In progress.
    Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
      what DC_DC are you using?
        Its a DC converter i designed while ago ...
        Pretty similer to Sroggys design ... with on board noise filter and stuff...
        output voltages
        +5 @5Amp Nominal
        +12 @1.5Amps Nominal (Flyback)
        -12 @0.250 Amps Nominal
        -5 @0.250 Amps Nominal
        Input voltage 8-16V
        Fosgate
        Fosgate
          An 8A fuse should suffice but if you want tighter protection use 5A
            Hey Fosgate, could you post your design of DC-DC PS? If you can,email it to me:
            [email protected]
            Thanks!
            Enjoint life!
