M2 ATX 160W P4 connector voltage.
  • M2 ATX 160W P4 connector voltage.
    Hi guys. For some reason i can not get 12V from the P4 connector of the M2 ATX 160W. I get 11.90V. And i was wondering is that okay to power my monitor? The monitor is working just fine in the car but there are some vertical lines which are barely noticeable if you stare at the monitor up close than you can see them. When i was testing it at home i did not see this. So is that voltage fine or i can kill it if i continue to use it?
