DC Power Supply for XBox or PS2
  • DC Power Supply for XBox or PS2
    Does anyone know if their are 12v DC power supplys available for an XBOX, PS2, PSONE, or N64 or something or do you have to use an inverter?
    thanks
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
    I know the PS one (the redesigned original PSX) has a cigarette lighter adapter... My guess is that the XBOX has a regular PC power supply inside(most of it is pc parts), so you could probably crack it open and use a DC-DC power supply.
    - CML
      hmm......
      i would like to just buy a cheap psone since it is so small, cheap, and compact and use it in the car. I can just cut the cigarette lighter adapter and wire it to my battery, right? Thanks
      any other info on this subject would be A+++
        I'm not an electrician but that sounds about right - second opinion here please. You need to make sure you can tell the negative wire from the positive, or else wire one of these to your battery.
          That would work, but make sure you get the polarity right and use a fuse!
          edit: U can use a multimeter to check the polarity.
          My Setup
            There is a company that produce a DC converter for the PS2 that replaces the PS2 AC/DC PSU. Can't remember the name, but I did post something about it in the last couple of months.
            4x4 in a turbo stylee.
              IVe got one of them...
              But it's caused me loads of noise and interferance in the audio and video lines... that i wouldnt recomend them !!!
              also im on my second one ! cos the first one went up in smoke ! with the PS2 in standby mode ! and not even on !
              I though the second one would be better..... because the first one was faulty.. but it's NOT !
              www.t1ny.com
                theres a 12 volt power adaptor for the GAMECUBE.
                no jokes on the game cube
                then again i own an xbox, ps2 and a game cube and love them all
                play the cube more often then the others as well
                mp4runner.com
                  well i have an XBOX and dont want to move it to the car, I have a nintendo64 I have hiding in my closet I would love to use (would i need an inverter?) but I wouldnt mind buying an inexpensive PSONE if they already make a DC adapter for it (plus its so small) but if anyone finds an alternative to an inverter for the N64 please let me know. thanks
                    does the n64 have a wall wart?
                    if it does, try finding a 12volt adapter with the same specs at rat shack
                    mp4runner.com
                      ummm..... can u define wall wart?
                        the big black things you plug into the wall, the transformer/regulator/rectifier
                        they stick out kinda like a wart on the wall
                        [H]4 Life
                        I'm a lesbian too.
                        I am for hire!
                          oh........gotcha
                          so for the n64 question its No, right? because it has no transformer thinger
                            just buy an inverter and you can use it on any system you want..
                            Philip Plante
                            my projects:
                            idgn.org | idgnonline.net | contrastsolutions.net
                              is there a dc-dc xbox replacement psu?
                              My cars
