HD Radio Help
  • HD Radio Help
    I recently reformatted my carPC and now I cant seem to get the HD Radio to work. I can control it via RR or the stand alone HD Radio program, but all I get is static. I would think this would be a signal issue except it worked perfectly before I reformatted. Unfortunately, I cant find the display for my Visteon to see if it is PC related or tuner related. Any suggestions?
    Car PC parts Purchased [90%]
    Car PC software Setup [80%]
    Car Audio setup [60%]
    I havent bought the directed hd radio tuner yet (i assume that is what you have) but have you checked the device manager to make sure the drivers are installed? Like I said I dont own it yet but it probably needs serial drivers for the interface cable.
    Check your device manager and see if there are any items with an exclaimation point.
      Drivers are all squared away. I can change the station via my pc, but only static comes in. Its looking more and more like I have a faulty antenna cable. I bought a display for the HD radio and I still have the same problem when the computer is not attached.
